12-12-2018, 10:28 PM | #15 |
Drives: 2018 ZL1 1LE Join Date: Apr 2018
My system has the Prospeed Intercooler and the Prospeed fender tank. I have a 10% lower pulley, ARH Long Tubes, Cam and E85. I can tell you that I monitor IAT2 constatly and when the car is moving it’s NEVER more than 15F above ambient temp. When I do WOT pulls the IATs will actually cool down to approximately 10 above ambient and for prolonged driving like uphill mountain road, my IATs stay between 15-20 above ambient. I’ve seen IAT2 as low as 55F when on freeway in 50F weather.
I know this isn’t a log but I can tell you mine never wavers from this formula. The stock LT4 heat exchanger is laughably small. It’s woeth the upgrade |
12-12-2018, 11:49 PM | #16 | |
Drives: ZL1/335i Join Date: Apr 2014
I have IAT2 displayed a lot of the time on my P3 gauge, so I’m pretty in tune with how it’s running. I’ve always been impressed with how cool it runs. But I’ll get some more data when I can. |
12-13-2018, 08:10 AM | #17 | |
Drives: 2017 Camaro 2SS Join Date: Dec 2016
12-13-2018, 09:30 AM | #18 | |
12-13-2018, 10:23 AM | #19 |
Ok, thanks BMW. I just want to figure this out. I'm pretty sure I have my sensor calibrated correctly in HP Tuners and the harness is plugged in correctly.
I have checked temp with an infrared and it reads the same as the P3 gauge. I am at a loss! I just want to see these wonderful temps everyone talks about. I am starting to wonder if it is something in the tune, something with the higher compression of the LT1, or just my s**t luck haha. |
12-13-2018, 11:10 AM | #20 |
So Matt with Lethal Garage dealt with the same issue and it’s just an LT1 issue. IAT2 is calculated and not actual like the LT4. But if your thermal laser is confirming the temps then thats odd.
I can tell you when we built my LT4 we had a similar high temp issue and one of my factory cooling bricks in the SC itself somehow became clogged. Might be worth a check. |
12-13-2018, 11:37 AM | #21 | |
12-15-2018, 11:58 PM | #22 |
Okay, so I took the car out for a few drives today. I didn’t pay much attention earlier, but tonight I watched everything took note of temps and driving conditions.
I started out in my garage after parking the car 5 or 6 hours earlier. IAT2 was at 81 degrees, with the temp in my garage showing as 67. I then drove 7 miles to my parents house. It was about 56 degrees on my drive, and as long as I was moving, the IAT2s continued to drop. They eventually seemed to settle at 68 degrees. This was driving on the freeway at 70+ mph. After a few miles at low speed with some stop lights and such, the IAT2 was up to 72. I then parked it for an hour and a half. When I got back into the car, it had obviously heat soaked and was up to 92 degrees. I took the same route back home, and again, it dropped back down to 68 or so. I got into boost a couple times, and the IAT2 actually dropped. The lowest I saw was 63. The outside temp was 54 at this time. The only time I saw temps climb (other than sitting with the engine off), was if I was idling with no movement or airflow. When I got home, I let it idle for 10 minutes. It got up to about 110 degrees. I’m guessing it would have kept climbing, as the engine temp was a lot higher (about 175). After that, I took a 15 minute cruise down by the beach. This was 30-50 mph driving with the occasional stop light or stop sign. Again, it didn’t take long for the temps to come back down to 68 degrees. Outside temp was still about 54 degrees. So my conclusion is about the same as before, despite an almost 40 degree difference in ambient temperature. 12-14 degrees above ambient is about average for normal driving. It can be even lower if the engine is sucking in a lot of air. Heat soak (parking with engine off) or long idle periods are the only way my car will get over 100 degrees. And even then, it recovers quickly with any airflow over the heat exchangers. For reference, the car is stock cooling wise, other than a 160 thermostat. It has a 2.30” blower pulley as well. |
12-20-2018, 09:30 AM | #23 | |
01-07-2019, 11:38 AM | #24 |
Sorry for the late response here, but for those who have responded or even those with experience on the LT4 swapped motor, what are possible causes of the increased blower temps?
I have ADMs reservoir installed so there shouldn't be any air in the system. Also, have the WeaponX intercooler. Since this is an LT1 the Baro sensor is not wired up...not sure this would have any effect. Again due to being an LT1 the bypass valve is not electronically controlled. I also have the base of the blower case plugged off with nipple removed. I am truely baffled on why my temps are so much higher than everyone else. This weekend for example the P3 gauge showed temps from 110-120* under normal city driving and freeway cruise with outside temps at 74*. |
01-07-2019, 12:32 PM | #25 |
So, just for current readings. Just took the Camaro out to grab lunch. Has been parked for 5 hours and started at 100*. Dropped to 98* during high idle warmup then quickly rose back to 100-102* as RPMs fell. Cruise on freeway was 110*. Parked the car for a total of 5 minutes...temp up to 132* when I started again. Lowest the temps got on the trip back which included a short 1 mile freeway cruise and stop/go traffic around 30-35 mph was 129*.
Outside temp 74* There must be something causing the high temps...what could cause this? This is a complete nuisance when I want to be able to take the car for trips longer than 10-15 miles from home, but don't want to have such high temps. |
01-07-2019, 03:29 PM | #26 |
Drives: 2018 Camaro SS Join Date: Mar 2018
Not sure if it's helpful but, on the SS, the IAT2 temps are a mix of IAT1 vs ECT. Lower airflow leans more towards ECT's than higher airflow.
IAT2 can be changed to bias more towards IAT1 in HPTuners, Engine > Airflow >General and it will be in the Cylinder Charge Temperature section. I'm 98% sure when I messed with this before, I could change my IAT2 temps to read more inline w/ IAT1 actual temps. |
01-07-2019, 04:03 PM | #27 | |
I swear I will figure this out, but for now any insight will prove helpful. |
01-07-2019, 05:06 PM | #28 | |
There's also a Filter table that controls how fast the bias (IAT vs. ECT) changes when airflow changes. Good luck. |
