10-26-2018, 02:44 PM | #1 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Bias ply tire/wheel that clears stock set up
Is there a choice or two, or should I run a drag radial. I've always heard/read that you run a bias ply on a manual unless you want to break things. Thanks for any help. I guess that would also safely require a bias ply front runner. Probably gets expensive.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
10-26-2018, 03:30 PM | #2 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
This is from one of my other posts. I have the tires, waiting for the wheels to ship, should have them next week, they were on back order. I felt like i got a good deal when I spoke with Mike at Kent's hot rod garage. Racestar recommended him for a wheel and tore setup.
Front Wheels: Race Star 92's 17x4.50 5x120BC 1.75"BS GLOSS BLACK Tires: M/T ET FRONT 27.5/4.0-17 (skinnies) Rear Wheels: Race Star 92's 17x10.5 5x120BC 7" BS GLOSS BLACK Tires: M/T ET STREET R BIAS 28x11.5-17 I currently run MMR M228 (gen 5 z28 replicas) and continental extremcontact tires. Going to this drag pack I will save 27 lbs at each rear corner, and 42 lbs at each front corner for a total of about 138 lbs just in wheels and tires, all rotating mass!
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
10-26-2018, 04:27 PM | #3 |
Shifts under load
Thanks, I will check those out
10-26-2018, 05:48 PM | #4 |
I run the 28x10-17 hoosier slick on a 17x9.5 race star polished wheel and 17x4.5 up front with 28" tall skinnies. Pretty good 60' ft also w/1.45 being my best and probably average 1.50 depending on the track.
10-26-2018, 07:17 PM | #5 |
BAMF SS
Bias ply offers more protection as it absorbs the drivetrain shock in manuals. It is also more forgiving in finding the "sweet spot" of launch rpm and tire pressure.
Some people avoid mixing bias ply rears and radial fronts. If makes it feel like the car is swaying back and forth on the top end. It doesnt effect performance, but can make people feel uneasy. I've done it before on my 4th gen.... wasnt that bad.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10-28-2018, 12:04 AM | #6 |
Shifts under load
Looks like about $2k for the least expensive wheel/tire set up. I'll probably continue on my Michelins and try to get in the 1.90's and see what happens.
10-28-2018, 07:26 AM | #7 |
My setup from above was about $17?? Shipped.
10-28-2018, 09:11 AM | #8 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I wanted a 26" tire for a better effective rear end ratio with the M6. I was disappointed that MT does not offer their MT ET Street Rs bias ply in 26", so I just went with the Street Rs 275/40/17 for my RaceStars. Not as much meat on these so hoping they will be less prone to cause breakage than a wider tread width DR and since I am not planning to change front tires, no rear end wiggle that some indicate if I had a bias ply in the back.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
10-28-2018, 05:16 PM | #9 |
Shifts under load
^ Thanks, sounds like a good plan I may consider.
10-31-2018, 05:48 AM | #10 | |
10-31-2018, 08:22 AM | #11 | |
10-31-2018, 07:13 PM | #12 |
Drives: 1987 Buick Grand National Join Date: Mar 2016
M&H Bias Ply in 26x8.5 - 17. Only bias in a 26" tall tire for a 17" rim.
10-31-2018, 08:02 PM | #13 |
The R has a softer sidewall than a s/s. The m6 that broke stuff was on bias plys makes you wonder
11-01-2018, 03:58 AM | #14 |
