10-18-2020, 08:57 AM | #1 |
Drives: 2018 ZL1 Join Date: Sep 2016
Cordes breather box
Does anyone have a cordes breather box on their zl1? I was wondering if you can text me or email me some pics of how its set up, connections and placement of the box itself. Thank you
10-18-2020, 10:51 AM | #2 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Recommend the Elite Engineering E2X vs any vented can
http://www.eliteengineeringusa.com/e2-x-catch-cans/ |
10-18-2020, 12:33 PM | #3 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
My .02 though is that ALL catch cans are better than no catch can on a DI engine so use whatever you prefer, just get one. Last edited by Z OH 6; 10-18-2020 at 02:47 PM. |
10-18-2020, 01:43 PM | #4 |
I'd like to see a comparison to MM, the Elite is proven to work. Vengeance probably likes the larger fittings/hose but the main issue is velocity through the can and removal efficiency, not just big lines. Vent to engine bay (vs closed loop) could also be a warranty issue
10-18-2020, 02:46 PM | #5 | |
10-19-2020, 11:56 AM | #6 |
Actually many catch cans aren't very effective - velocity is too high or no baffling so oil doesn't drop out effectively
10-19-2020, 07:45 PM | #7 |
Petro-sexual
It seems like too much flow from some of the vented-style catch cans could be problematic, as was what was found on a current MM-build on one of our Member's cars. If I understand correctly, a restrictor had to be added in the system.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // TooHighPSI Port Injection // FF // Katech Dual In-Tank // Soler 103 // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
10-19-2020, 08:14 PM | #8 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Yep that was me. Way to much vacuum was pulling into the can filling it up. 8oz in 100 miles and into the intake it went, fouling plugs and loading the magnuson with oil. The old can had a different style clean output, think it was like a small barb fitting that could be drilled, widened if needed more vacuum. New one is similiar to the dirty side, just a big fitting, hole twice the size. They put the restrictor inside the clean side of the vacuum line. I get a teaspoon or less now in a few hundred miles. and its now crankcase gases etc and not pure oil . So yes, match up correctly the type of can and setup you have so it works properly. A can with a cam and a can with stock cam yields 2 different results especially the vacuum at idle. |
10-19-2020, 11:01 PM | #9 | |
Elite installs the restrictor under the blower. It just seems like there is more science and thought that went into their design.
Have yet to see any of the other guys actually post results |
10-20-2020, 04:23 AM | #10 | |
10-20-2020, 04:25 AM | #11 |
10-20-2020, 06:48 AM | #12 | |
10-20-2020, 06:52 AM | #13 | |
10-20-2020, 08:04 AM | #14 | |
Thread Tools | |
