dave@hennessey
Old 10-14-2020, 11:10 AM   #1
chris777
Drives: a pile currently
Finally I have joined your cult!
Been wanting this body style since 2009 when they first came out. Ended up purchasing a Black 2013 2SS. Manual, Cammed, and aftermarket hood.
Couple questions!
1. I really like the look of the satin/matt black wrapped hoods. Good idea or not? And how much typically does it take to wrap a hood?
2. I travel with a large cup. Don't leave home w/out it. The cup holders get in the way of shifting gears. Anyone purchased extra cup holders successfully? I found some on amazon, just curious experience before I waste my time.
3. Cammed sound. I fkn love it. Loud as piss. But...my wife..think it's too loud. Is there a cheap/easy maybe portable way to add sound dampeners? Silencers I've heard of? Pros/Cons of this? Just curious of options.
4. What else do I need to know boys? Tips/Tricks?
That's all I can think of for now.
I'm in love.
chris777 is offline   Reply With Quote
Old 10-14-2020, 11:15 AM   #2
drew peacock
Drives: 2012 2SS INFERNO ORANGE
fantastic choice you made there mate. you will love it.
drew peacock is offline   Reply With Quote
Old 10-14-2020, 11:53 AM   #3
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Congrats!
Not sure about 1,2, and 4.
But as for 3, I would just get a new wife.
Old 10-14-2020, 12:20 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Congrats!! Enjoy the hell out of that machine!! Too loud?? Never. Put a set of cutouts on there, then you will be loud!! Oh and a new wife would be good too, my gap loves it especially with the cutouts open. Of course she comes from a drag racing family. lol. Have fun sir !!
1JEWLDSSRS is offline   Reply With Quote
Old 10-14-2020, 12:20 PM   #5
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Congrats on the new ride and welcome to the site. Matte wrap on the hood isn’t bad as long as you use a Matte detailer to keep it clean. Many people here have used or are using the travel buddy for the drinks. As for the exhaust what are you running now? You could always change it out for a quieter exhaust.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-14-2020, 12:26 PM   #6
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Get ready, it gets worse.
In the best kind of way possible!
ADVMax is offline   Reply With Quote
Old 10-14-2020, 12:33 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I wrapped my own hood for like $85 using 3M 1080 Satin Black. It's the easiest wrap I have ever worked with, but my stock hood is nice and flat. Not knowing the type of hood you have may change things. I think it's like $200-300 to have done professionally.
InFiD3ViL is offline   Reply With Quote
Old 10-14-2020, 12:39 PM   #8
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
For the cup holder, I have the following.
https://www.rpidesigns.com/shop/item.aspx?itemid=4986
I had to cut my weather tech floor liner on the passenger side for it to fit, but they are definitely worth it.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 10-14-2020, 12:51 PM   #9
Axe55
Drives: 2012 Camaro SS
Welcome to the family!
For the sound, I would check if you have a stock exhaust, if it's that loud I suspect it's not stock anymore, you can shop around for different ones that are quieter. Also, is it the noise in the cabin at certain rpms or is it all the time and outside the car? You might want to look into j-pipes if what you're hearing is drone inside the cabin, there are lots of threads about that.
For the cupholder, I recommend (edit: not with the beer, obviously):
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 10-14-2020, 01:04 PM   #10
BAD DAB
BAD DAB's Avatar
Congrats!!!!!!!!!!!
Old 10-14-2020, 01:18 PM   #11
chris777
hah, thanks guys! As for a new wife...i asked her if I could and she said no. Then she said "I have spoken!" and walked away.
Travel buddy looks good, tho $50 for a cup holder seems steep!
I don't exactly know the brand/model of the after market parts, I will try and get a list.
Old 10-14-2020, 01:34 PM   #12
Warship2k15
Ok how loud is it and what level would she be happy with if she is being reasonable then I would add some mufflers that lower the volume some bit not be restrictive for the wife.
Then I would add cutouts So that way you can have it loud when you want and she can have it a little quieter.
Now if she will only be happy if it’s whisper quiet then don’t bother and just drive it.
Cammed cars with free flowing exhausts will always have a rumble.
If you put one on that quiets it a lot then it will be too restrictive.
I would try to talk her into a AGP turbo kit.It would lower the exhaust a lot and you would have a faster car.
Warship2k15 is offline   Reply With Quote
Old 10-14-2020, 01:45 PM   #13
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Congrats!
Old 10-14-2020, 01:52 PM   #14
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Welcome to the dark side. Let the wife drive the car for one day and she will change her mind.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
