Old 01-31-2020, 10:31 PM   #1
Chomorro
Drives: 2010 Camaro SS
Debating lowering my 2010 SS
I love the look but man I just cant get a feel for where the front end is on this thing. I feel like I would crush the bumper in no time LOL.
It's time for new shocks too so I was thinking oem shocks and set of pfadt springs.
Anybody lower it and hate the ride so much they went back to stock?
Sent from my SM-N950U using Tapatalk
Chomorro is offline   Reply With Quote
Old 01-31-2020, 10:46 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Nope.
I mean I'm pretty good at parking usually and these cars still have me judging it wrong but I error to cautiously and I'm always a foot away. It really bugs me I haven't got the distance feels yet haha.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 01-31-2020, 10:48 PM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Doubt many went back to stock. If you are needing shocks though you might want to consider a set of coilovers then you can adjust the height to what you like. You will have to make sure you don't pull up on curbs, i already don't because some are too big for even stock ride height. Good practice to not pull up close. I am installing 1-1/4 lowering springs more from phastek. Haven't gotten to see the finished project yet
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 01-31-2020, 10:59 PM   #4
Chomorro
Honestly I cant even parallel correctly in this car. I'm always like two feet from the curb. The wide rear messes me up hahha.
Old 01-31-2020, 11:45 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I found a good way to go up/down inclines is to approach it diagonally or at an angle. This way you aren't scraping your nose too hard.
As said above, stay a good 6-12 inches away from those concrete parking stops. At stock height my front splitter was only about an inch above most of those. Now? Forget about it. I would likely rip it and my front bumper off.
InFiD3ViL is offline   Reply With Quote
Old 01-31-2020, 11:55 PM   #6
curt.r
curt.r's Avatar
Drives: a Chevy
Nope. I lowered mine on 1" SLP springs and prefer the ride quality over factory. The body roll is significantly reduced and feels much more confident in corners. Like others said, if you're going to be replacing the springs, why not just get some coilovers?
2011 Camaro 2LT/RS - BBK LT Headers w/ High-Flow Cats, MRT v1 Axle-Back, Cold Air Inductions CAI, SLP 1" Drop Springs, Vitesse Throttle Controller, Drake Billet Shifter, NPP rear diffuser, B.E.S.T. Stainless Steel Quad Exhaust, Clear Smoked Side Markers, Anvil Notch Spoiler, SS Front Bumper, Heritage Grille, SLP front splitter
curt.r is offline   Reply With Quote
Old 02-01-2020, 12:30 AM   #7
Chomorro
Well I found a set of used springs for $100 so the cost difference is significant for coils.
Old 02-01-2020, 02:14 AM   #8
Keoni068
Keoni068's Avatar
Drives: 2015 Camaro 2LT RS
I installed a set of BMR springs with a 1” drop, but it was only a matter of time before I went with BC Coilovers, which give a much nicer stance. My suggestion: avoid paying twice by going straight to coilovers.
Keoni068 is offline   Reply With Quote
Old 02-01-2020, 06:52 AM   #9
Greenhornet2
Springs are cheap, i mentioned it because you said you were going to do the shocks too.
Old 02-01-2020, 07:29 AM   #10
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Another point of contention is the dreaded speed bump.
Sometimes I have to plan trips based on their speed deterrent concrete.
joshnmn is offline   Reply With Quote
Old 02-01-2020, 09:16 AM   #11
travfreed
travfreed's Avatar
Drives: 2010 Camaro RS
Question for you all. I was looking at coilovers but my mechanic told me that if I went to coil overs to lower the ride, I would have to change a lot of other suspension parts in the process. Is this statement true?
Sent from my SAMSUNG-SM-N920A using Tapatalk
travfreed is offline   Reply With Quote
Old 02-01-2020, 09:28 AM   #12
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I just back it in wherever I can, otherwise I'm at least a foot from the parking blocks.
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 02-01-2020, 10:04 AM   #13
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
If you are just lowering a inch then you are fine. Only need to change things if you are slamming it to the ground
Bigdumogre is offline   Reply With Quote
Old 02-01-2020, 11:02 AM   #14
curt.r
curt.r's Avatar
Drives: a Chevy
Springs are relatively cheap. How much did you find 4 struts for? I've heard if you're going to change your struts and install lowering springs, the 1LE struts are the way to go as long as you don't go lower than 1.25" .
