05-05-2019, 04:04 PM | #1 |
Problem after vvt cam install
Finished up a vvt cam install on my 2011 SS. Went with GPI SS1 vvt cam and also got remote tuning from Ryan at GPI. Installed the tune and the car started and ran fine. Took it out on the road and it ran fine for a couple of miles then lost power and died and now it won't start. Has anybody else had this happen?
05-05-2019, 04:08 PM | #2 |
Drives: Camaro Join Date: Oct 2018
You’re going to have to give us more info than that
05-05-2019, 04:16 PM | #3 |
I heard what sounded like an exhaust leak right before the car died. It turns over, but will not start. Pulled plugs and they are white indicating that it was lean. Rechecked all connections. Not getting a check engine light
05-05-2019, 05:40 PM | #4 |
Think it might be fpcm related. When my friend installed the tune, hptuners asked if he needed to write to the fpcm which required another credit. Did we screw something up by writing to the fpcm? hp tuners website says we only needed 2 credits for my car, but he used 3.
05-05-2019, 05:41 PM | #5 |
I’d imagine his tune would be bit on rich side depending if you were logging afr. Just to be clear, you were driving and lost power. How much was it driven before this happened since you said it ran fine.
Edit...it should have cost you 2 credits |
05-05-2019, 05:51 PM | #6 |
We got about 2 miles up the road and it died. No fuel pressure at the rails now and don't hear the fuel pump priming
05-05-2019, 06:40 PM | #7 |
Check all fuses and connections. Pretty much everything you touched during the install?
05-05-2019, 06:48 PM | #8 |
Yes, all fuses and connections are good
05-05-2019, 09:09 PM | #9 |
Drives: 45th anniversary camaro ss Join Date: Sep 2014
Sounds to me like it`s your fuel pump, I had the same thing happen to me. I took it to the tuner, he used the laptop not dyno. On the way home it just died, but I was able to get it started and drove drive about ten more miles at 10 mph before it stopped completely. I got a ZL1 pump from a friend installed it and no more problems.
05-05-2019, 09:31 PM | #10 | |
Drives: Never just fly under the radar Join Date: Jul 2015
Perhaps someone else with experience can chime in here???
Old Skool |
05-05-2019, 09:54 PM | #11 | |
05-06-2019, 02:59 AM | #12 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
I know that with the latet stable and beta release there's a warning during the writing process that states it's brickable. Hopefully that is not your case.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
05-08-2019, 01:00 PM | #13 |
Wouldn't it have likely bricked right after the flash? He ran it a few times before it died.
05-08-2019, 07:28 PM | #14 |
Just a quick update. I'm thinking it may be the battery. Battery was getting weak and I was waiting it out. Did a log while cranking the car last night and had quite a few indications that it's something electrical. Going to change the battery tonight after work and see what happens
