TireRack
Old 01-14-2019, 05:21 PM   #1
stang stopper
Drives: 45th anniversary camaro ss
Retainers
Do I need to purchased new titanium retainers when I change out the springs? It`s a BTR STAGE 4 cam with titanium when it was installed.
stang stopper is offline   Reply With Quote
Old 01-15-2019, 10:48 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
nope.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-16-2019, 08:58 AM   #3
xc_SS/RS
Drives: 2010 Camaro SS/RS
Originally Posted by Batmanntexas View Post
nope.
What's more expensive a new set of titanium retainers or a new engine?
OP: buy new ones! Cheap shit compared to dropping a valve due to a busted retainer
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-16-2019, 09:14 AM   #4
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
We just had a guy loose a Ti retainer and drop a valve. Supposedly Ti does wear much quicker than the steel retainers and is probably something you want to replace when you do springs.
I was (an still am) on the fence on retainers - I went with the steel because the extra 5 grams didn't bother me all that much, and I intend on putting lots of miles on my setup, and probably going through a few sets of springs. However, I wasn't really thinking I'd be turning this thing much past 7000rpm when I spec'd it out and bought parts. Now that I've got it all together I find it very happily makes power all the way out to 7300rpm, which is as far as I've been willing to go, and I find myself thinking maybe I should have got that extra 5 grams off the intake valves.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 01-16-2019, 01:58 PM   #5
suprchrgd
Drives: 2015 2SS 1LE
I'm under the impression and with how my springs looked after putting 22k miles on my stg 4 btr cam. The springs retainers, and valve seals should all be replaced every 20k miles. even if my lifters had not failed, i had a couple valve seals going too, so I would have still has some issues...
505/465: 416 stroker, landspeed stg 3 heads, 10.5 compression, btr stg 3 stroker cam, E85, kooks 1-7/8" headers,k&n intake,vmaxx tb,mgw,rxt,bmr 1.5" drop springs,bmr poly cradle bushings,bmr toe rods,bmr trailing arms,bmr uca,bmr diff bushings
suprchrgd is offline   Reply With Quote
Old 01-16-2019, 02:01 PM   #6
Batmanntexas
I definitely agree with it being cheap insurance. Just speaking from my experience, having never seen a broken or worn retainer.
COTW 9/8/14
Old 01-16-2019, 02:10 PM   #7
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
At 20k miles I'm replacing all my springs and assosicated parts. High performance valvesprings dont have the service life of a stock valvetrain, there is a lot more load on things.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 01-16-2019, 03:25 PM   #8
stang stopper
I really appreciate the input guys. New springs it is.
Old 01-16-2019, 03:31 PM   #9
xc_SS/RS
Gotcha, apologies for my comment then. I didn't know it wasn't a normal occurrence until doing some research.
2010 2SS/RS
Old 01-16-2019, 04:01 PM   #10
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
I had never seen one until mine failed Saturday.......
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 01-16-2019, 04:05 PM   #11
zz430camaro
Drives: 2015 1LE
Ya, it's rare that one lets go.
Old 01-16-2019, 05:34 PM   #12
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
BTR told me don't use the titanium retainers if the car is a daily or going to get a lot of miles. Just a heads up
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 01-16-2019, 06:37 PM   #13
lazerlemonta
Drives: 2010 C6 1LT
I have a set on a car that’s been 90k miles. Mine had 50k. Really it’s hard to say why it failed. Really “good” titanium retainers are about $500
Best MPH 134.82
