03-17-2022, 12:33 PM | #1 |
Drives: Chevy Camaro, Dodge Charger Join Date: Oct 2021
Diff fluid part number change?
After reading through the not so sticky diff fluid change thread I went to my dealer and asked for ac delco 10-4034. They brought out two quarts of 10-4016 SAE 75W-90 GL-5 and told me this was the updated part number.
Can anybody confirm if this is the right stuff because I’m not feeling to confident the parts lady was right. Thanks!
2022 SS 1LE 2SS 6MT on order. BDZHD3
03-17-2022, 12:36 PM | #2 |
Drives: 2021 Camaro 1SS 1LE 10AT Join Date: Jul 2021
I wouldn't trust that, the 10-4034 has a limited slip friction modifiers, don't see a mention of that in this P/N.
2021 Camaro 1SS 1LE 10AT (Track)
2019 VW Golf R DSG (Daily/AutoX)
03-17-2022, 12:39 PM | #3 |
Yeah, after a bit more research, don't use that, you should get 10-4034. I'm coming up on the track hours for my second diff flush and will be using 2 bottles of 10-4034 again.
03-17-2022, 12:59 PM | #4 |
Alright, thanks @snekk, I’m wondering if this is the fluid for the NON 1LE SS.
03-17-2022, 07:09 PM | #5 |
Nope, the owner's manual calls for GM 88862624 / AC Delco 10-4034 for my standard 2SS as well.
03-18-2022, 08:24 AM | #6 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
I bought some for my SS last summer and it came in a different shape bottle. I don’t remember the part number. Go back to the dealership, ask them if you can return it/exchange for the correct part number. The best way to get correct things like fluids for your car are to give them the VIN number. GM changes part numbers so much. Their computers should be able to match the correct fluid for your specific car.
03-18-2022, 10:04 AM | #7 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
The diff fluid part number has not changed. The parts folks gave you the wrong stuff.
I just did my diff last weekend and got the fluid over the counter from my local dealer.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-20-2022, 09:21 AM | #8 |
Drives: 10'ss/rs Join Date: Nov 2013
That is the correct bottle 10-4016 you also need 10-4003 additive 4oz. Called two dealerships in two different states , both said this .Dont know if that is a new change ?
03-21-2022, 07:43 PM | #9 |
get 88862624 from Amazon...additive already in the fluid. LS gear oil
04-07-2022, 12:55 AM | #10 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
next oil change im swapping to Redline 75w90 gl5 with friction modifiers. theres no way a $22.86 bottle of Acdelco is going to be better than a polyolester oil base stock of Redline at only $18.95!!
04-07-2022, 11:09 AM | #11 |
Drives: Chevy Camaro Join Date: Jan 2022
I was just about to ask... I've always used amsoil stuff and was thinking it HAS to be better as well. If I'm wrong whatever, I don't know shit about friction modifiers
'22 2SS 1LE manual in Red Hot with Red seat belts, alloy pedals, PPF, catch can, and suede kneepads.
04-07-2022, 01:36 PM | #12 | ||
Drives: 2016 2SS Convertible Join Date: May 2012
04-07-2022, 01:48 PM | #13 |
Years ago a friend had the differential on his 2012 ZL1 fail due to a problem with the coating GM used inside the differential. There was a TSB documenting the problem and replacement. He still had to produce receipts to prove that he performed recommended maintenance with an approved fluid before GM would authorize the dealer to replace the differential under warranty. Redline and AMSoil may very well be better than the AC Delco fluid but you might want to make sure they meets the fluid requirements before you use one of them.
04-07-2022, 05:35 PM | #14 |
long as its in there i think you'll be fine. a huge company like Redline isnt going to say its for your car and its not for your car. and again youre starting off much better of an oil. Redline and Motul are best base stocks unless Amsoil no longer uses a di-ester.
