08-05-2021, 09:36 PM | #1 | |
Drives: 2020 Camaro 2SS 1LE Join Date: Feb 2018
Randy Pobst: SS 1LE vs. Mach 1
Randy Pobst has uploaded his track comparison of a 6th gen SS 1LE vs the S550 Mach 1 with the Handling Pack. The SS 1LE was on what appeared to be C7 ZR1 wheels (likely aftermarket replicas) with the same model and width tires as the stock Mach 1 HP.
Key Points: -Mach 1 was a 10-speed auto, SS 1LE was a 6-speed manual -Mach 1 was 0.4 seconds faster around Atlanta Motorsports Park -SS 1LE felt wrong to Randy, brake fade and mid-corner oversteer he claims were not present in SS 1LEs he's driven previously My takeaway is that IF there truly was some issue with the brakes and alignment like Randy claims, the SS 1LE would probably have won without those issues present. However, the Mach 1 won that day. Maybe next time the tables will turn, just gotta bring a properly setup stock SS 1LE to the party. All that aside, the Mach 1 HP is still $12,650 more than a 1SS 1LE with a 6-speed. Is 0.4 seconds per lap worth $12,650?
2020 Camaro 2SS 1LE
2018 Mercedes-AMG CLA45 - Sold 2016 Camaro 2SS - Sold 2014 Camaro RS - Sold Last edited by STReddy1999; 08-05-2021 at 09:39 PM. Reason: fixed price difference |
08-05-2021, 10:00 PM | #2 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Great video. Yeah the .4 seconds is not that much coming from a vehicle that cost more than the Camaro. Who knows about the 1LE he was driving. The brake fluid could’ve been bad or needed to be changed, maybe the camber needed be adjust on it but who knows. Even Randy know the 1LE drives better than that. However the Mach 1 don’t look special to me. Maybe I need to research more into it but it just looks like a badge swap from a GT without any fascia changes which I dislike Ford for. 1LE is still a great bang for buck
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
08-05-2021, 10:54 PM | #3 | ||
Drives: 2017 2SS Join Date: Aug 2017
BUT...he is super sensitive to this stuff, my guess is that the car must have really been different than stock for him to have commented. Really the crazy thing to me is how expensive Mach 1 is. Its almost Zl1 money for a car with a coyote. |
08-06-2021, 12:39 AM | #4 | |
Drives: 1SS 1LE Join Date: Jul 2018
Atlanta Motorsports Park - Dawsonville, GA
1. 1:28.67 - jpdaugherty in '17 SS 1LE on 10/21/18, OE Goodyear's, track Last edited by Wontspeak; 08-06-2021 at 12:50 AM. |
08-06-2021, 05:59 AM | #5 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I wonder if not using the stock 1LE tire sizes is why the car didn't feel quite right.
08-06-2021, 06:19 AM | #6 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
08-06-2021, 08:20 AM | #7 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
40K mile car, ya possibly without the OE pads on it, alignment quite possibly.
08-06-2021, 09:43 AM | #8 | |
Drives: 2SS 1LE Join Date: Oct 2011
The 20s on the stock 1LE hold it back for sure. It was inevitable that they would make faster cars than the SS 1LE, but it sure took a while.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
08-06-2021, 10:13 AM | #9 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Sounds right on the tires, or tire brand characteristics. Only 10mm less stagger vs stock but maybe just enough for more oversteer (?) heck with 305 sq I need the bigger hotchkiss front bar on to help with oversteer just in autocross
08-06-2021, 10:26 AM | #10 |
cup2s are meh stock goodyears 3s are better lol
08-06-2021, 10:31 AM | #11 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
SLE's braking feel can be greatly improved by switching out lines and fluid. I'm running the cf braided lines offered here + brembo fluid, this results in a much firmer and more immediate feel, fluid can handle higher temps vs OEM.
IMO, the SLE needs better brake fluid, but otoh they can't use an OEM fluid that may go bad too quickly. The better brake fluids require more frequent changing and cost a lot more.
08-06-2021, 11:08 AM | #12 |
Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
Not really a fair comparison with the 40k miles on the ss 1le, mystery allignment, pads, manual vs auto, etc. but what can you do. .4 seconds is basically nothing - regular drivers in these it is a drivers race.
since the mach 1 came out later, I would imagine they benchmark it against a ss 1le pretty heavily? I can't imagine ford being okay selling this car and it being slower than a ss 1le thats been out for several years already, but sounds like that may be the case. I think the mach 1 is kind of a cool car. basically a gt350 without the voodoo that has had a bad rep for reliability. then again, the gt350 is as popular as it is because of the voodoo. I think I would have considered the mach 1 much more if it was priced a lot better. this car is just not special enough i think for how expensive it is. |
08-06-2021, 11:10 AM | #13 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
I bet this camaro was a victim of the prior owner not feeling like cleaning brake dust all the time which makes sense given the miles. Most likely did not have the oe pads and had something way less aggressive.
08-06-2021, 01:46 PM | #14 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Sucks he couldn't get a brand new or properly maintained 1LE with factory correct wheels and tires as well. Next.......
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
