08-22-2020, 06:24 PM | #1 |
Drives: 2013 Camaro 2SS/RS 6MT Join Date: Aug 2018
ARP Header stud kit vs header bolts
Yes, I searched, didn’t find much on it.
The next project for my Camaro is headers and exhaust. Picked up these barely used Kooks headers for $500. I’m in the process of getting everything required for the job. Looking at ARP header studs specifically. The appeal of easier header installation and good looks has me sold. Has anyone run this model specifically? If so, any tips or things that are a little wonky for our application?
1964 Chevrolet Impala 327/Powerglide Coupe - SOLD
1978 Chevrolet Camaro Z28/4 Speed Hardtop - SOLD 1993 Cadillac Fleetwood Brougham - SOLD 2000 Acura Integra GSR/5 Speed - SOLD 2013 Chevrolet Camaro RS/SS/6 Speed - NEVER SELLING |
08-23-2020, 04:55 PM | #2 |
Drives: 2012 Camaro SS Join Date: Jun 2019
I literally installed my headers yesterday, and if that's a picture of what you're getting, pretty sure you're 2 short, I needed 6 per side, 12 total. I used bolts, not sure if the fastener makes a big difference, but from what I read, I'd stick with the GM gasket, others seemed to get bad feedback on leaking.
Good luck with install!
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
08-23-2020, 06:17 PM | #3 |
Started#gottalovethatblue
Be sure to remember exactly where the oil dip stick tube goes because getting that thing back in is a pain. Also spray your O2 sensors with PB Blaster the night before and again before you start disassembly. WD-40 will not work, but PB Blaster can save you from needing to buy new O2 sensors because of ruined threads. Other than that it's pretty straight forward.
08-24-2020, 03:41 PM | #4 | |
08-24-2020, 03:49 PM | #5 | |
08-24-2020, 04:01 PM | #6 |
Yep. The front O2 sensors are what the extensions are for and you'll definitely need them. There's a few other little things with installing like tighten bolts first to 10 ft/lbs then to 18 ft/lbs then recheck again after a full heat cycle to 18 ft/lbs again. Also GM manifold gaskets are best to use. Don't bother with the gaskets from the header companies and especially the goop that some try to include with their headers.
08-28-2020, 01:51 PM | #7 |
Drives: 2014 1ss camaro Join Date: Jul 2017
I put my dipstick in the tube and fished it into the block no problem you can see the hole with no problem by flashlight . its so easy doing it that way
08-28-2020, 03:33 PM | #8 | |
First time I removed mine for my header install I got it back in within 30 seconds like it was nothing, almost like it was meant to be. When I did my engine swap it took me over an hour to get the damned thing in.
08-29-2020, 11:26 PM | #9 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
are you running cats with those or going catless? I’m selling new unused kooks3” to 2.5” connectors for those...if in need of course /shameless plug
08-31-2020, 06:37 PM | #10 | |
It’s cool, I already have the Kooks catless connection pipes, they’re just not pictured.
