Old 07-22-2020, 05:23 PM   #1
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Tail Light Trouble
Hi all,
Earlier today I was installing my Borla S-Type axle back system (Btw thank you all for the suggestion). As I was about to complete the install, I noticed that my drivers side brake light was on but very dim.
I am very stumped as to what is causing this to happen and trying to find a fix. If anybody has any recommendations as to what I can do please let me know!
Thank you
(Link to video of the light)
https://youtu.be/lTXplnGcT08
Azerlazer26 is offline   Reply With Quote
Old 07-22-2020, 06:40 PM   #2
Rhobz
Rhobz's Avatar
Drives: 2018 Camaro 1SS 1LE
Do you have LED bulbs installed? I don't know if it is the same but when you install aftermarket LED reverse light bulbs, they "glow" unless you add a resistor.
Rhobz is offline   Reply With Quote
Old 07-22-2020, 06:52 PM   #3
Azerlazer26
I do have LED reverse lights installed with a resistor from Phastek Performance.
Old 07-22-2020, 07:54 PM   #4
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
The resistor might need replacing
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 07-23-2020, 06:02 AM   #5
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Did you buy the crimp on resistor kit or the plug and play resistor kit? If it is the crimp on you might have a bad connection.
dmcmahan60 is offline   Reply With Quote
Old 07-23-2020, 08:53 AM   #6
Azerlazer26
I bought the plug and play kit.
Old 07-23-2020, 09:00 AM   #7
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
The only thing I can think of is check to make sure the plug connectors are together tight.
Old 07-23-2020, 10:20 AM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
I know on the 19 the plug and play resistor kit don't work, at least on my car it did not, and lots of others it did not.
2SSRS@Gen5diy is offline   Reply With Quote
Old 07-23-2020, 11:38 AM   #9
Azerlazer26
Finally got to taking the lights apart. I think I found the issue...
Old 07-23-2020, 02:05 PM   #10
ste1n
Drives: 2019 2SS
Water?
ste1n is offline   Reply With Quote
Old 07-23-2020, 03:39 PM   #11
Azerlazer26
Originally Posted by ste1n View Post
Water?
That’s what it looked like. I truly don’t know how water seeped into the connections!
Old 07-24-2020, 10:41 AM   #12
ctrlz
Shine a light in the female end and make sure the gasket isn't cracked or twisted.
I think you could introduce a small amount of silicone grease in there to add some insurance. Vaseline is also a possibility, as that will swell a rubber-based gasket. Don't know what these plug gaskets are made of. Could be Viton.
Old 07-24-2020, 11:25 AM   #13
Azerlazer26
I’ll definitely take a look and try out the grease. Thanks you for the tip!
Old 07-27-2020, 09:22 AM   #14
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Might try moving the plug to a different location because there is a water run off channel for the trunk lid in that general area.
