Old 06-17-2019, 02:11 PM   #29
oldman
Drives: SS 6 speed of course
please snap some pics. OK stupid question, does the Holley fit under the stock hood?
Old 06-17-2019, 02:28 PM   #30
CesarT
Drives: '17 1ss
What do you need pics of? The holley does not fit under the stock hood
CesarT is offline   Reply With Quote
Old 06-17-2019, 04:05 PM   #31
oldman
That's what I thought, like to see what it looks like installed... please
Old 06-29-2019, 01:44 PM   #32
Daaaaan
Daaaaan's Avatar
Drives: 18’ 1LE H/C/IM
Do you plan on modifying your stock hood to get it to fit or going aftermarket? Also where did you pick up the ported high ram? Thanks
Daaaaan is offline   Reply With Quote
Old 06-29-2019, 10:28 PM   #33
Trochoidal
Drives: 2017 Camaro 2SS A8
Ahhh, I’d like to see pictures of your setup too, please.
Old 06-30-2019, 02:51 AM   #34
Carnage_SS
Drives: CMaro
I trapped the same speed with 479hp
Carnage_SS is offline   Reply With Quote
Old 06-30-2019, 09:16 PM   #35
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
The limiting factor for power range on these engines is not the valvetrain, it's the shitty stock intake manifold. Thanks to the C7 the 6th gen had to suffer as well. With VVT, we can still make good use of the added rpm the high ram adds.
I was thinking the stock cam table was as good as it gets at 10 degrees? and there are no gains to be had by changing it from stock? (Corvettes and the LTI crate motor have +1 more degree I believe at higher rpms). I haven't tried to mess with mine but I am assuming we need more retard, as in increasing it past 10 at high rpms? (6000+)?
cmitchell17 is offline   Reply With Quote
