03-12-2024, 05:53 PM | #15 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Are all 8 cylinders looking like this? While 87 octane is not optimal, it's shouldn't cause this. I believe something else is going on.
Bad primary 02 sensors? Bad MAF? Bad MAP? Is fuel pressure in spec? Get a good scanner on it to log some data and see where the misbehavior is coming from.
03-12-2024, 06:18 PM | #16 |
Bad primary 02 sensors? Bad MAF? Bad MAP? Is fuel pressure in spec? Get a good scanner on it to log some data and see where the misbehavior is coming from.[/QUOTE]
I thought this too, but he says his LTFT's are good. If they're within 3% or so it shouldnt cause this, but then again oil consumption I would think would look wet unless it was just a small amount coking on the plugs.
03-12-2024, 09:33 PM | #17 |
Drives: 2011 Chevrolet Camaro SS A/T Join Date: Aug 2022
03-12-2024, 09:55 PM | #18 |
Drives: 15SS Camaro Join Date: Dec 2020
One cylinder is @ 116 psi? If it is thats way too low and probably has piston-ring land damage.
03-12-2024, 11:13 PM | #19 | |
03-12-2024, 11:17 PM | #20 | |
I'll check when I'm home and let you know the results. |
03-12-2024, 11:30 PM | #21 | |
Yes, all 8 cylinders looking like this. Fuel pressure 57 psi on idle. As i know on high rpm it should be less. I have the second reserve MAF - Delphi AF10142, can try it but it seems that engine runs more rough with this MAF |
03-13-2024, 04:25 AM | #22 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
03-13-2024, 04:52 AM | #23 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Does your oil smell like fuel?
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
03-13-2024, 06:09 AM | #24 |
Maybe I missed it, but is your mod list for this car? Might shine some light on the topics.
03-13-2024, 10:21 AM | #25 |
03-13-2024, 10:26 AM | #26 | |
At the moment they are not there, they have disappeared and appear rarely from time to time |
03-13-2024, 10:28 AM | #27 |
03-13-2024, 10:32 AM | #28 |
I was told to check the resistance of Cooling Temp Sensor and check that it's value corresponds to the correct temperature...
I've replaced my coolant sensor before this winter because I accidentally broke my old one. But I installed the original one ACDELCO 2134514...... (almost original except for GM 2134333) I found this table and going to check this at weekends. Also I have a little bit air in the cooling system, I can hear it in the mornings |
