Old 07-20-2015, 06:02 PM   #1
Cars and Tea
Cars and Tea's Avatar
Drives: 2013 Camaro 2SS/RS
What R Compound/Track Tire will fit the Gen 6 wheels?
What R Compound/Track Tire will fit the Gen 6 wheels? and what tire will you pick?
Cars and Tea is offline   Reply With Quote
Old 07-20-2015, 08:40 PM   #2
Mr Twisty
Mr Twisty's Avatar
Wait till we know what size wheel fits over the 6 piston brakes, then possibly go with a 18 or 19" wheel tire combo
-- Benjamin Franklin
Old 07-20-2015, 08:48 PM   #3
Cars and Tea
Agreed, but I meant on the stock wheels.
Old 07-21-2015, 06:58 AM   #4
conemark
Drives: Boost Coupe Stewie formerly '01 Z28
It looks like a few 20 inch DOT-R compound tires are available from Continental, Dunlop, Michelin and Pirelli. The front 20 x 8.5 could probably take a 255/35 or 265/35 and the rear 20 x9.5 wheel as the widest factory wheel available, a 295/30 looks to be feasible.
If you're looking at the stock wheels, only the 18 inch standard LT wheel would have the much liked Hoosier A6/A7 or R6/R7 R-compound available.
conemark is offline   Reply With Quote
Old 07-21-2015, 09:44 AM   #5
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
That's what I'm going to do. 18" if it will clear 6 piston Brembo. If not, 19".
Square set up.
I think Gen6 Camaro probably will be faster than my LS2 C6 on the track. I'm getting excited~!!!
jaymsu is offline   Reply With Quote
Old 07-21-2015, 01:48 PM   #6
SPCBA
Drives: pleather and Chiclets
More and more r compound for 20s. R888 and NT01 are options in addition to some brands named carrying a r compound
Easy solve for fifth gen was run 4 rear wheels for the r compound.
SPCBA is offline   Reply With Quote
Old 07-21-2015, 03:23 PM   #7
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Good idea to try and save some money, but if you want R compounds (expensive) on your stock wheels, you'll wear them out on the street...
I would spring for some lighter weight 19s for R compound and tracking...
Switch back to your stock tires and wheels for the street....
Old 07-24-2015, 01:06 AM   #8
LbulletM
LbulletM's Avatar
Drives: 2007 Corvette Z51
I'm hoping for the same!
LbulletM is offline   Reply With Quote
Old 07-24-2015, 02:19 PM   #9
BigEnos
Planning stages...
Drives: 1995 Z28,2014 Ford Focus ST
Are you really stuck on having R-comps? The new 140 or 200 treadwear ultra high performance tires are pretty damn good. The Bridgestone RE-71R is great. The 20" size is a challenge, but like others have pointed out, a 19" wheel for track use is a great idea, and you can go with a different width.
I plan to run my car in SCCA street class, but I'm waiting until/if the 1LE is announced. I'll probably go down an inch in diameter if they stick with 20"ers on that variant.
BigEnos is offline   Reply With Quote
