03-09-2019, 10:02 AM | #1 |
Drives: fast Join Date: Nov 2018
big turbo, misfire
Hi, first of all, the mod list:
new forged engine efr7163 turbo(.80 t4 twin scroll) custom exhaust manifold(42mm inside) zzp cam ngk spark plug 90543 ILTR7E9(0.035") zzp air intake kit zzp intercooler kit AEM water-methanol injection kit premium fuel Just after I finished my big turbo plan, I tune it with HP. It was really strange that if the pressure was 22psi, everything is ok. But when I tried to increase the pressure level, then the car started act like misfire since WOT. The exhaust sounded like "pop" and "boom". I've checked the fuel pump pressure (in-tank) and it's ok, the spark plugs were new and the coils were good. I can't figure out what's the problem. Maybe the exhaust manifold is too thick?Or the turbine house is too big?Did I need to re-gap the spark plugs?Or chane the fuel pump with a high flow one? I really need some help. |
03-09-2019, 10:05 AM | #2 |
Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
Im not sure gap or heat range on sparkplugs you should be using, but increasing boost may be blowing out the spark and causing the misfires. Just a guess, maybe try closing the gap and seeing if any difference?
03-09-2019, 10:15 AM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
v8 here. at 20psi I was getting spark blow out at .028. I took them all the way down to .020 and that fixed that problem. then above 6500 rpm I was getting a hard miss and that was valve springs. I had good springs but they were not installed at the correct height. once they were shimmed properly that problem went away.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
03-09-2019, 10:30 AM | #4 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
I don't have any experience with the particular plug you are running, but I successfully held 24'peak psi with NGK 6510's, gapped @.028, with no misfires on the stock turbo, before switching to a non-projected tip style plug.
Also, posting a log in HPT could be helpful as well. Might be a fuelling issue. But, your gap is definitely on the high side.
03-10-2019, 12:35 PM | #5 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Sounds like spark blow out. I've had it a couple times. I've had good luck getting rid of it taking my gap down to .029"
03-18-2019, 12:08 PM | #6 | |
Drives: 2019 Chevrolet Camaro 1LT 2.0T Join Date: Mar 2019
I have the RaceChip installed on my car and that's it, performance-wise. |
03-18-2019, 06:38 PM | #7 |
Drives: Cadillac ATS 2.0T Join Date: Feb 2019
I would never run a gap larger than .028 even on a stock car and would be down in the .024 range or lower in your case, depending on your target boost. I run 6510's at .026 at 22+psi, but on stock turbo.
Thread Tools | |
