Old 11-30-2018, 02:53 PM   #29
Mountain
Mountain's Avatar
Originally Posted by Whitespeed View Post
I got the RPI Designs side skirts. Fit was good, but the satin paint finish also left something to be desired. It's apparent to me they were shot quickly and with not enough coats. They have a rough texture like the spray was half dry by the time it hit the surface.
In retrospect, I wish I had bought the unpainted fiberglass. Satin is easy to spray with a spray can and I could have done a better job myself. Like anything, it just takes preparation and patience. I'm going to end up redoing mine.
Nigel
I keep going back and forth between the RPI Design ones and the ACS ones (ZL1 style). I would paint them myself (1LE satin black: WA848+satin clear). Any comment on the RPI's coverage and protecting against rock chips?
Old 11-30-2018, 03:06 PM   #30
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
I have the RPI side skirts (painted them to match mirrors and spoiler) and the ZL1 Addons rock guards and they have eliminated the rock chip hazard for me.
lgarrison34 is offline   Reply With Quote
Old 11-30-2018, 09:25 PM   #31
Mountain
Mountain's Avatar
Good to know! Thanks.
Old 12-02-2018, 08:30 AM   #32
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
C7. Fit was ok. Finish is OK �� enough. One side better than the other. Just looks thin and primer like. Didn't complain. Screws and rivets. And a trip to a shop as I couldn't get same rivet on both sides to bight. One drilled hole at rear you won't get a rivet in. Just made another hole wear the angle and gun head would work.
Would I do it again? Probably ACS. Would I wrap or paint and all that? No. I'd just likely get ACS.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 02-13-2019, 08:48 PM   #33
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
Has anyone seemed to notice alot of chips on the ACS or C7 side skirts from rocks? Is it worth it to wrap them in Xpel for protection too?
artey34 is offline   Reply With Quote
Old 02-14-2019, 07:40 AM   #34
ToeKnee Sea
Drives: 2018 Camaro SS 1LE
has anyone ever done or seen a video for side skirt installs?
ToeKnee Sea is offline   Reply With Quote
Old 02-14-2019, 07:42 AM   #35
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Yes. Did you try searching YouTube?
Whitespeed is offline   Reply With Quote
Old 02-14-2019, 10:18 AM   #36
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Simple
Hold them up, clamp in place, drive in screws.
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 02-17-2019, 06:56 AM   #37
Soleil
Soleil's Avatar
Here is one.
https://youtu.be/YmB7DvjPGy0
Soleil
Old 02-17-2019, 09:24 AM   #38
Kentucky74
Kentucky74's Avatar
Drives: 2018 ss 1le camaro
I have the Acs side squirts and their rock guards in satin black. Matched my 1le perfectly, quality is top notch. The rock guards look great too!
Kentucky74 is offline   Reply With Quote
Old 02-17-2019, 09:57 AM   #39
artey34
artey34's Avatar
I have the ZL1 add-ons rock guards and those help. The side skirts should eliminate the rest of the chips. However I do too want the side skirts banged up. Should I get these wrapped in Xpel? Has anyone noticed these to get chipped easily?
Old 03-19-2019, 10:06 AM   #40
RyanR3KC
"1/LE Rebel Alliance"
RyanR3KC's Avatar
Drives: 18 Black 1SS 1LE “Siouxsie
anyone use these? far cheaper option
https://zl1addons.com/collections/ca...13217281343551
RyanR3KC is offline   Reply With Quote
