Old 11-28-2018, 10:55 AM   #1
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
C7 Carbon Side Skirts
Hey guys. Anyone have experience with the C7 carbon side skirts on their 1LE? I was thinking about pulling the trigger here soon but was curious on their fit and finish for the cost
Anyone go with the Carbon fiber ones over the Satin black? Pics? Not sure what ones would looks best on the hyper blue
https://www.c7carbon.com/2016up-cama...on-fiber-p-656
https://www.c7carbon.com/2016up-cama...9c7765273ca26e
Thanks!
artey34 is offline   Reply With Quote
Old 11-28-2018, 12:30 PM   #2
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
This thread should help, a few different options and opinions here:
https://www.camaro6.com/forums/showt...ight=C7+carbon
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 11-28-2018, 12:36 PM   #3
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I have them. I got them in “1LE Satin”. I can tell you that the fit of the side skirts are on point. However, their finish leaves a lot to be desired. It’s a very rough texture and doesn’t match our satin very well. A quick wrap would likely solve that issue, however.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 11-28-2018, 12:40 PM   #4
artey34
artey34's Avatar
So in this case I would be better off just getting the unpainted fiberglass version and then get it wrapped in Satin Black?
Old 11-28-2018, 01:10 PM   #5
USAFS197
USAFS197's Avatar
I don’t think that’s a bad idea at all, honestly.
2018 Audi TT RS
2019 Audi RS3
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 11-28-2018, 04:50 PM   #6
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
what about cover with PPF? Wrap will get torn up like my hood
Old 11-28-2018, 08:04 PM   #7
artey34
artey34's Avatar
That was my thoughts also. Either get some already done in Satin Black and then get Xpel Stealth on them like I did my whole car. Or, get some in just primer, wrap it in Satin Black, then do Xpel Stealth. Both will cost similiar I assume. But if the one from C7 doesnt match or has a rough feel to it, then it sounds like I should get the non painted one.
However, the carbon fiber one does look glossy and smooth because that is essentially a wrap as well. So I could get that, then Xpel clear wrap it.
Old 11-28-2018, 08:15 PM   #8
jwcassidy1969
Drives: 2018 red hot 1le
Don’t do it they are terribly painted . Me and a friend ordered them and returned both sets and went with ACS. They are perfect match and paint is as close to stock pieces as you can get. Cost more but worth it.
jwcassidy1969 is offline   Reply With Quote
Old 11-28-2018, 08:22 PM   #9
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Love mine
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 11-28-2018, 10:38 PM   #10
artey34
artey34's Avatar
Love mine
Ryan B.
So only some people complain about quality on these? They look pretty good to me!
Old 11-28-2018, 11:14 PM   #11
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I have them and the quality was great.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 11-29-2018, 06:06 AM   #12
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
I have a pair - seem built well, but as stated above the "1LE Satin" finish leaves a little to be desired. My is a close match on color, but the "sheen" is off vs the mirrors, hood and splitter.
I wanted the rock protection so I am happy with the results
Just don't be in too big of a hurry - I was given three weeks as a ETA when I was ordering, turned out to be six when it was all said and done
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 11-29-2018, 07:41 AM   #13
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Acs vs c7
Do the acs ones require holes to be drilled on the bottom and the lower angled section of the rocker panel like the c7 carbons or just the bottom? I'd prefer some where only the bottom part needs holes drilled.
RobbyBeefcake87 is offline   Reply With Quote
Old 11-29-2018, 08:37 AM   #14
Goldfish
Drives: 18 2SS 1LE
You can attach them with just the bottom ones, but if you accidentally put your foot on the skirt when you get out, you're going to want the angled rivets installed.
Goldfish is offline   Reply With Quote
