02-09-2016, 01:30 PM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2015
New Era Air intake
Anybody using a New Era Air intake? I installed on on my 2013 SS and now my idle stumbles a little. I had a K&N Typhoon prior with no issues. Car does have a tune. Tunecwas done with the K&N installed. New ERA has been on for a couple hundred miles now. Any thoughts?
02-09-2016, 02:15 PM | #2 |
Drives: 2013 2SS/RS L99 Join Date: Oct 2012
I have the New Era on my car and never had any problems with no tune or tuned!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley 12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's! 12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best 10.72 @127.93 after heads and Cam and Yank SS3600 |
02-09-2016, 02:36 PM | #3 |
Give New Era a call. I was just there yesterday. They are an awesome shop and I'm sure will help you trouble shoot any issue.
02-09-2016, 03:01 PM | #4 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
Had similar issue, when i noticed the MAF connection was not actually fully seated. Once it was fully plugged in issue was gone.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
02-09-2016, 03:18 PM | #5 |
Drives: 2013 SS Join Date: May 2013
NewEra here..... Car did idle funny when it was real cold and did a little tune adjustment but love this intake
02-10-2016, 12:21 AM | #6 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I have same idle issues will check maf sensor connectio talked to new era they seemed to think its an air leak dont know but i love this intake had a halltec with scoop and new era made a big diference
Ported intake manifold and throttle body kooks 2" headers no cats
02-10-2016, 04:33 AM | #7 |
check to see if the filter was over oiled. is the maf oily
02-10-2016, 07:56 AM | #8 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
02-10-2016, 10:25 AM | #9 |
Would not think that one CAI versus another would change a custom tune. Why did you switch from one to another?
Fix your garage pics so we can see them |
02-10-2016, 11:03 AM | #10 |
Drives: cars Join Date: May 2011
MAF scaling for an OTR is very different than all of the others with same pipe style and diameter. Changes in pipe diameter also requires tuning mods.
02-10-2016, 11:26 AM | #11 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Do you have that metal plate installed?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
02-10-2016, 11:44 AM | #12 |
I do idleing has gotten a bit better but not gone
02-10-2016, 02:56 PM | #13 |
Yes, metal plate is installed. I switched after reading about the intakes and one came up for sale at a good price. I figured I would give it a try. I did not notice any difference except for the rough idle and a little hood turbulence, at high speed, I guess from the extra ai thats coming in from tilting the radiator forward.
02-10-2016, 04:35 PM | #14 |
Drives: ‘13 1LE Join Date: Jul 2013
It's high time for someone to data-log with this type of intake on, while experiencing this idle hiccup, and end this debacle once and for all.
