Old 07-03-2023, 07:14 PM   #1
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Hardwire kit fuse connect on 18 1LT
I put a hardwire kit on my 18 1LT mirror cam. So I thought I’d post the fuses I used in case anyone with a LT needs the information.
There’s not alot to pick from.
Always on fuse is F17 Camera - ACC fuse is F55 Radio Controls
Nut to loosen for the Ground wire you need a 6/16” nut loosener .
I got a Wolfbox G900 only 2 things I don’t like. When the rear camera is on you see both the camera picture and the back window which is confusing so I shut the rear camera off and use it as a rear view mirror instead of having the camera on.
Second to use it as a mirror it’s to close to the ceiling with the plugs on top of it so I put a cork between the rear mirror and the mirror cam seems to work. It’s that or use the rear camera and it doesn’t show the back window without the cork in it.
NYJets12 is offline   Reply With Quote
