TireRack
Old 11-07-2017, 06:06 AM   #1
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
One way to get brakes and clutch to work better.
At almost 70K miles my SS clutch was not as great as it once was. Well last week had real bad odor coming from the car, almost like gasoline leak or something. Opened the hood and the brake reservoir was covered in brake fluid and it was dripping down on the header.
So I had the shop replaced the break cylinder which was leaking and new reservoir came with the cylinder. Now the car stops allot better and the clutch feels like it is brand new.
Scott@Bjorn3D is offline   Reply With Quote
Old 11-07-2017, 09:02 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
did you ever bleed the brakes or clutch? empty and refill the reservoir? I follow this http://www.rangeracceleration.com/Clutch_Care.html ...
good luck!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 11-07-2017, 09:23 AM   #3
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Thank you for the link! This will be my weekend project after my pedal got stuck to the floor after launch at the strip Saturday
good luck!
LsxDoctor is offline   Reply With Quote
