Old 02-21-2024, 05:51 PM   #29
Agree 100%. I’ll never run headers that are not ceramic coated. Been 4 years here with coated headers and no starter issues. Granted, I never drive the car. But still.
If I'm brutally honest, I don't drive my car that much either, but my ceramic coated headers also work extremely well, no issues with heat whatsoever.
Old 02-21-2024, 05:55 PM   #30
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
So how the hell would you know then?
Seriously though, does the ceramic coating REALLY make that big of a difference? Did you have any issues with starters before? Like you know, when you USED to drive your car?
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
FJB
Dynamical is offline   Reply With Quote
Old 02-21-2024, 06:06 PM   #31
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
FYI putting down 1059 WHP makes a fair amount of heat my friend…
If you take a close look around under the hood, there is a good amount of wiring, plastic, and rubber that are closer to the exhaust than I’d prefer. The ceramic coating has to have helped….worst case it helped my OCD.
Joshinator99 is online now   Reply With Quote
Old 02-21-2024, 06:22 PM   #32
Dynamical
Dynamical's Avatar
No doubt!
I do know the issue exists. Or at least that's what people have posted. I will probably wrap my starter unless there's a downside that outweighs it.
I do know the OCD feeling and I have to keep that in check myself. That's why I made a pledge to myself I would not get into serious weight reduction on this car because THAT, is the one that will make me insane
FJB
Old 02-21-2024, 06:32 PM   #33
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Originally Posted by MyNameIs View Post
I have a drop in K&N filter in the stock box.
I would strongly recommend an actual CAI, or even just using stock air filters over that. The ONLY benefit to the vast majority of those drop in air filters is that you can clean and reuse them. As far as performance goes, many don't do a thing, some even hurt, and some actually don't filter out everything they should be filtering out.
For such a small cheap part its best to do it right, I just hate how drop in air filters got really popular and everyone jumped in to make their own and none of them turned out very good in testing. I think Green Filters are the only ones worth even looking at, but even then I would just invest in a real CAI.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
Black on black 2019 3LT RS Camaro.
1100: 3/7/19 | 4200: 4/15/19
3100: 3/15/19 | 4800: 4/23/19
3400: 3/22/19 | 5000: 4/25/19
Built: 4/8/19 | Home: 4/26/19
RideWithDanger is offline   Reply With Quote
Old 02-21-2024, 06:36 PM   #34
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
If you ceramic coat your headers, you shouldn't have any starter issues. I installed all of the mods in my signature around 25k miles ago. The only heat related issue I have experienced is one melted MSD plug wire. I have around 20 full-day track sessions with these mods
Where do you get your headers ceramic coated?
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 02-21-2024, 08:26 PM   #35
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
To answer your question yes.
coated headers, drop header temps down to maybe 200 degrees sometimes less.
My uncoated headers reach upwards of 900 degrees F
But the starter issue people are talking about are specific years, my car is not one of them.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
Old 02-21-2024, 08:49 PM   #36
Joshinator99
I used a company in Southern New England, Central CT Coatings. Did a great job. I had my shop weld in an extra bung in the collector then drove it down to the coaters for coating before installation.
Old 02-22-2024, 05:32 AM   #37
Dynamical
Dynamical's Avatar
Thanks. Sounds good to me.
I'm assuming the starter issues were before your year so mine should be good too. I'll find out
FJB
Old 02-22-2024, 08:42 AM   #38
FlukeSS
FlukeSS's Avatar
Ya, the starter issue was because GM screwed up and used the wrong heat shielding for the starter housing, which ultimately melts the electrical wiring for them.
I don't recall exact year, but I want to say 2019-2020+ are safe, I thought there was a website we can look up our cars on to determine if we had to worry about it. TSB maybe?
Old 02-22-2024, 08:58 AM   #39
Capricio
Drives: 2000 WS6
Originally Posted by Eric10905 View Post
Second this. ^^^
I might start a thread to ask who regrets doing headers. I regret them.
But, if you do them, take the extra time and $ and ceramic coat them. Esp if you ever plan to track.
Sincerely, I appreciate feedback like this. Its too easy to seek affirmation/validation on mods after expending all the money/effort/time. Knowing the marginal increase in performance and dealing with clearance, heat, and sealing issues, after reading what I've learned here, I'd probably stay away from headers. The OEM ones are actually not bad. It's hard to say how much of the gains from the headers are from improved flow vs just a good performance tune.
Capricio is offline   Reply With Quote
Old 02-22-2024, 01:38 PM   #40
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
No worries, we all have our own opinions, that's just mine.
For me, between cost of headers, hi flow cats, ceramic coating, install, then car being too loud for my taste (and sounds limits at a local track), adding a magnaflow X before the suitcase muffler, I'm sure I spent over $2 or 2.5K. In reflection, wish I had spent it somewhere else on the car. Other folks may not. I am probably being too particular about it.
Good luck on your choices!
Eric10905 is offline   Reply With Quote
Old 02-22-2024, 02:37 PM   #41
bdavies11
I wouldn't say that was the issue. I think it's more of an electrical resistance issue than a "heatshield issue". I had the starter issue on hot days after use for about 3 years (only in summer of course) and I'm 100% stock. I also had the dealer install a heavy duty heat shield while I was still under warranty for my starter problems but that didn't do anything to help. What finally fixed it was adding an extra and beefy ground cable.. I think GM just didn't use a big enough gauge ground from the battery and with increased heat, comes increased electrical resistance and the ground they used from the factory just couldn't handle the job on hot days. I haven't have a starter issue in about 4 summers now.
bdavies11 is offline   Reply With Quote
Old 02-22-2024, 03:46 PM   #42
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
My car is stock SS 6 spd except with ported Throttle Body. How much more HP and Tq can I expect with Long Tube headers going through my stock NPP exhaust? Its a 17' that I bought new, now with about 68k miles.
I have a 2017 2SS with the 8-speed auto. I did Kooks 1 7/8 inch headers and cats going into the stock NPP.
I can't seem to find my dyno graph but I do remember the average gain was about +25 HP and TQ.
But headers do much more than increase power and torque on these cars. After 5000 rpm, the stock manifolds power and torque drops off of a cliff.
The long tube headers don't drop off anywhere near as much. At 5000 rpms to redline, the stock exhaust rapidly power and tq start to drop and then fall off a lot. At 6500 RPM's with the headers, HP and TQ is about 50 to 60 more at the same RPM with the stock exhaust. And you can really feel it. The car feels like it is accelerating harder.
It is actually quite amazing the gains above 5000 rpm. Do it.
Spaceme1117 is offline   Reply With Quote
