Old 12-28-2009, 08:19 AM   #1
scomaro22
scomaro22's Avatar
Drives: 2010 VR 2SS! ,'09 Genesis
HELP! Fuel malfunction code after CAI install
Ok so I know this should be in the exhaust section BUT I know that there are usually more people looking through here, so my dilemma is this......I got my Volant CAI and put it on the car. It was a simple install, and looks great, but less than 5 min after installing it and on the road, my computer set off a fuel malfunction code . Then, another light popped up on my dash, and my tire pressure monitor system cleared, and the car asked me if I wanted the car to re-learn ????? Huh ????? So, I assume the fuel malfunction is because of the CAI, but the other code setting off is throwing me off here. The obvious thing is to take the car to the dealership, but before I do that, any suggestions or has this happened to anyone else ???
2010 Victory Red 2SS 20" Polished Wheels
Delivered 8/3/09 !!!!!!!!
scomaro22 is offline   Reply With Quote
Old 12-28-2009, 08:27 AM   #2
Ravirn
Account Unaccounted for
Ravirn's Avatar
Drives: Black SS
I have no idea. All I know is if it transforms into a 40' tall robot and starts yelling that it needs oil... you better give it some oil!
It would help if you could tell us which codes it's giving you.
WARLOCK (Black 2SSRS LS3) - A work in progress.
Ravirn is offline   Reply With Quote
Old 12-28-2009, 08:36 AM   #3
scomaro22
scomaro22's Avatar
If that was the case, I'd def not be complaining about it
You mean like the actual number codes ??? I don't have those I just know that the malfunction icon came up (then engine block symbol ) and the exclamation point icon for service tire pressure monitor....
Old 12-28-2009, 08:50 AM   #4
steeleshark2
steeleshark2's Avatar
Drives: 2010 Transformer 1SS Camaro
Make sure your masairflow sensor is in the correct direction (it might only install in one direction only I do not remember). Verify all connections to make sure they are tight especially the breather line. Also unplug the battery for a few minutes and then retry it. Post pictures of the install and I can give it a dummy check!!
Also, what other upgrades are on your on Camaro? If it is cold, check your tire pressure, it could be just low. With it as cold as it is, you might be throwing lean codes.
steeleshark2 is offline   Reply With Quote
Old 12-28-2009, 09:03 AM   #5
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
I would pull the battery cables off to reset all and see what happens.
To reset the tire pressure, just hold the press button the left steering wheel arm (same that you scroll through odomoeter, etc.). This has happened a few times to others and you may get away with resetting fuses 5 and 20 in the fuse box (Elect Control Module), but a batt cable pull will definitely reset all. I would surely try this before going to the dealer.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 12-28-2009, 09:03 AM   #6
scomaro22
scomaro22's Avatar
MAF is in correctly, all the connections are tight, especially the breather line. I am posting pics in a min
Old 12-28-2009, 09:04 AM   #7
scomaro22
scomaro22's Avatar
To reset the tire pressure, just hold the press button the left steering wheel arm (same that you scroll through odomoeter, etc.). This has happened a few times to others and you may get away with resetting fuses 5 and 25 in the fuse box (Elect Control Module), but a batt cable pull will definitely reset all. I would surely try this before going to the dealer.
Ok cool I will try that as well. Thank you for the help. I will let you guys know how it turns out once I do it.
Old 12-28-2009, 09:05 AM   #8
calflan
calflan's Avatar
I just edited my post - it is fuses 5 and 20, not 5 and 25.
Old 12-28-2009, 09:06 AM   #9
steeleshark2
Also, what other upgrades are on your on Camaro? If it is cold, check your tire pressure, it could be just low. With it as cold as it is, you might be throwing lean codes. Volant is a very good and open CAI and makes you run lean without any tune.
Old 12-28-2009, 09:09 AM   #10
scomaro22
scomaro22's Avatar
O ok thanks
Old 12-28-2009, 09:11 AM   #11
scomaro22
scomaro22's Avatar
Only other thing I have on there is straight pipes running back to single chamber race mufflers. Thats it. I just had a tire plugged bc of a freaking rivet that I picked up along the way But its holding, so I dunno. The pressure is 35 all around.
Old 12-28-2009, 09:19 AM   #12
steeleshark2
Ok, on the mass airflow sensor, did you remove the little thin rectangle gasket at the base of it (where it seals against the stock intake pipe) and use the rubber seal supplied in the box. It is small and I missed it the first time I installed mine which made it install funny.
Old 12-28-2009, 09:29 AM   #13
scomaro22
scomaro22's Avatar
Hmmmmm, now you have me thinking......I do not remember removing one, but I did use the one that was supplied......O and for some reason my USB port won't function to put the pictures up, so these will be delayed.
Old 12-28-2009, 09:33 AM   #14
steeleshark2
If you goto your local autoparts store, call first. A lot of them will read the codes on your car for free.
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 08:26 PM
Roto-Fab CAI Install I8A4RE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 106 08-20-2009 05:01 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
Bob Lutz, and Scott Settlemire on fuel economy. Mr. Wyndham Off-topic Discussions 19 11-18-2007 02:01 PM
