Old 05-15-2020, 02:57 PM   #1
PROMETHEUS
PROMETHEUS's Avatar
Help
Afternoon,
The other day I installed a Roto-Fab and followed the directions. Today I took it out for a spin...….nice day. About 3 miles from the house, the warning lights for the engine and stabiltrack light up, along with service warnings for the stabiltrack and rear axle. Along with a loss of power!!! While legging it home, I got an email from OnStar that there is something wrong with the emissions.
My gut tells me the Soler TB, Soler Controller and the Roto-Fab are not playing nice. Called the dealership, will be taking in on Monday.
Any insight as to the problem is always appreciated. Thanks, Tony
Old 05-15-2020, 03:01 PM   #2
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
Dealership isn't going to be likely to do much with the aftermarket parts on there, other than maybe say take them off.
Did you try unhooking the battery for awhile? Basically, do the soler TB ECM learning method (the long one) and see if that helps...thats what I'd do as a first step anyways.
HoodCheck is offline   Reply With Quote
Old 05-15-2020, 03:05 PM   #3
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
Total shot in the dark here but if it’s not too much trouble, disconnect the battery, re-install the OEM box and try it again. I’m assuming we’re not about a Big Gulp as I understand a tune is required.
Good luck,
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 05-15-2020, 03:08 PM   #4
PROMETHEUS
PROMETHEUS's Avatar
no big gulp, no tune.
I suspect the TB, controller and Roto-Fab are not playing nice. I disconnected the battery when I got home. Will reconnect and see what happens.
Old 05-15-2020, 03:09 PM   #5
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
Was it working before the Roto Fab? I am assuming you had the first two already.
Revert back after trying the battery disconnected to reset it.
Paintslinger16 is offline   Reply With Quote
Old 05-15-2020, 03:10 PM   #6
PROMETHEUS
PROMETHEUS's Avatar
Will do! Was thinking that as a possible solution.
Old 05-15-2020, 03:11 PM   #7
PROMETHEUS
PROMETHEUS's Avatar
No previous problems with the Soler TB or controller. This was the first time I took it out since the install of the Roto-Fab
Old 05-15-2020, 03:15 PM   #8
HoodCheck
HoodCheck's Avatar
another thought too; check just to make sure connectors to the TB and MAF didn't get knocked loose during the CAI install. When I last swapped my TB back to stock, I completely forgot to plug it back in, got a shitload of messages on the dash lol (frankly, I'm impressed it ran at all).
Old 05-15-2020, 03:16 PM   #9
Paintslinger16
Two Lane Blacktop
Check the plug in connections again while battery is off, I just did the throttle controller yesterday and got all the dash lights limp mode etc, I started over and checked everything and it was fine when I rebooted the car.
Old 05-15-2020, 03:46 PM   #10
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I suspect it either just Needs a reboot or something isn’t plugged in right or something got damaged during your install. I have Soler TB and controller with Rotofab and mine ran great from the get go. I don’t think just having this combo is the issue.
CW3SF is offline   Reply With Quote
Old 05-15-2020, 04:39 PM   #11
PROMETHEUS
PROMETHEUS's Avatar
Just got back from taking it out! Disconnected the battery, reinstalled the OEM air box. Reconnected the battery and didn't get out of my driveway, before the warning lights lite up again!
Dam! Could it be the MAF sensor went bad? I didn't remove the sensor itself when I did the Roto Fab. I removed the two screws and laid the entire assembly on the SC out of the way. Oh well, the OEM air box is back on, it looks like a trip to the dealership is in my future.
Old 05-15-2020, 04:50 PM   #12
Paintslinger16
Two Lane Blacktop
Did you do all of this with the fob near by? Double check all the connections on everything you have touched including TB and TC And the MAF plu did u push the lock in
Old 05-15-2020, 04:53 PM   #13
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
I had a very similar issue after installing a vararam CAI on my 2005 GTO years ago. Turns out I had a bad wire in the MAF connector. Never an issue until I installed the CAI.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 05-15-2020, 05:16 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Remove the throttle controller and everything will be fine. No matter how many times these companies say they do not cause issues they always seem to. Clear the codes and everything will be good.
