Old 01-03-2020, 06:39 AM   #1
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
RPM signal under the hood
I'm trying to see if anyone has a way to solve this - its from snow stage 4 boost cooler kit install instructions:
I mean - any specific adapters or locations, experiences , etc..
"Finding an RPM signal: For a vehicle with port injection or sequential fuel injection you may find a square wave signal by tapping into a fuel injector wire.
For a direct injected engine the easiest way is to find the proper pin # on the OBDII port and tap into that."
wookwook is offline   Reply With Quote
Old 01-03-2020, 08:18 AM   #2
FdeleonZ28
Drives: 2016 camaro ss convertible
for my nitrous set up i used the green wire off the coil pack at the rear on the driver side to get rpm signal for my window switch.
FdeleonZ28 is offline   Reply With Quote
Old 01-03-2020, 08:49 AM   #3
wookwook
wookwook's Avatar
ahh. I think that is what is needed. Thank you. Is it a splice/contact or is there an induction sensor that would get it I wonder? I am asking snow tech if they had any knowledge as well. awesome pic btw.
Old 01-06-2020, 09:03 AM   #4
FdeleonZ28
No worries. and i used a splice connector. and thanks!
