06-17-2019, 09:45 PM | #1 |
Drives: 2018 2SS Join Date: Sep 2018
AFM Valve Delete - Tune Out?
Hey Guys,
I'm getting set to install the Kooks midpipes to my kooks headers w/cats. I don't have NPP but I do have AFM. I disabled the AFM/DOD in hptuners so it's always in V8 mode. Haven't tried it yet but if I disconnect and remove the AFM valves will i still get a CEL or can that be tuned out also? Or is it as simple as omitting those check engine codes related to the valves? Thanks |
06-18-2019, 09:23 PM | #2 |
06-18-2019, 09:24 PM | #3 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Just omit the check engine codes.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
06-19-2019, 05:36 AM | #4 |
Not engine codes technically. The AFM codes need to be disabled in the FSCM. It takes HP Tuners and one credit to license it, then you can go in and take care of the 4 codes that will pop up when you remove the AFM valves.
06-19-2019, 09:54 AM | #5 |
Drives: 2013 / 2SS / RS / L99 Join Date: Feb 2009
Do the M6 transmission cars have the AFM valves in their exhaust also ?
06-19-2019, 10:29 AM | #6 |
Drives: 2016 2SS 8AT Join Date: May 2018
06-19-2019, 10:41 AM | #7 |
