10-12-2017, 09:09 PM | #1 |
Drives: 2014 RS Convertible Join Date: Oct 2017
2LT but I can shift into Sport?
I've been reading through these forums, and the manual, and everything seems to say that a 2LT doesn't have sport mode and according to the owner's manual, I will never see an "S" on the screen. Shifting to M should activate ERS and just display M and the current or Maximum Gear#.
However, if I shift to M, the HUD shows "S" which is not possible per my manual. So am I misreading something, or is this just a pretend Sport mode? If it is a pretend sport mode, why does it exist?
New-To-Me 2014 Red Camaro 2LT RS Convertible (Also 1964 Jeep Gladiator with Chevy V8)
10-12-2017, 09:51 PM | #2 |
Drives: 2015 1LT/RS hot red/black Join Date: Apr 2016
I have a 15 rs auto i can go back and forth between the M & S using the paddles. Put it in the m position and it should be in S mode, the car will shift for you, but hold the gear longer depending on how much you get on it. It will hold 2nd all the way to redline in wot. If you want to go into m mode just pull the paddles and now you shift the car. If you want to go back to S mode and let car shift pull the upshift paddle and hold it in and you should go back to s or sport. Im not sure if that's what you want to know or not hope it helps ya
Sent from my SM-G955U using Tapatalk |
10-13-2017, 03:11 AM | #3 | |
Drives: 2015 2LT Join Date: Nov 2015
2015 2LT Cosmetics: ZL1/1LE Wing Spoiler, SS Carbon Hood, Z/28 Carbon Diffuser, SS Front Bumper, RS Taillights, 1LE Carbon Splitter, Phastek U-Halo Headlights, Fade-to-Black Gills
Performance: ZL1 NPP Exhaust, ZL1 6-Piston Brakes, ZL1 10-Spoke Wheels, Nitto NT555 G2 295/35/20 x 4, Magnaflow X-Pipe, Blackvue DR650S2-CH Dash Cam |
10-13-2017, 03:12 AM | #4 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Pull down to M with the gear selector, and you should get in sport mode. Do you have the LT or the LS? Select M, hold the right shift paddle for 2-3 seconds and the M should change to S.
10-13-2017, 08:00 AM | #5 |
I may be getting 2LS and 2LT confused. The manual just says camaro a with2.92 rear end which I thought I had
10-14-2017, 03:36 AM | #6 | |
"The 1LS and all LT Camaros (auto or manual) come with a 3.27:1 axle ratio. The 2LS, however, has a 2.92:1 ratio." All the info you need regarding this can be found here: http://www.camaro5.com/forums/showthread.php?t=307690
