08-03-2018, 07:44 AM | #1 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Lt4 in-tank fuel pump upgrade
Here are pictures of my original pump and the new zl1 pump. From the bottom to the hoses with little t adapters, it looks like there are completely different connections. Any help would be appreciated.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
08-11-2018, 10:56 PM | #2 |
For others that might need help on this:
1. If you have a convertible, you will need two other parts. 2. JRE will have them available for you so you can call to get the actual part numbers, but the parts will include cross over tubing and an extender basket. This is necessary because of the extra bracing on the convertible that caused GM to change the shape of the tank and the fuel pump also. With the two extra parts, you can get the ZL1 pump to work just fine.
01-18-2019, 11:23 AM | #3 |
Drives: 2016 SS Camaro Convertible Join Date: Nov 2018
Great info!
Thank you for the post, great info, in process of converting this summer!
01-18-2019, 12:46 PM | #4 |
I know ZZ Performance installed a LT4 fuel pump I'd recommend shooting them an email if you need help
10-24-2019, 09:27 AM | #5 |
Drives: Turbo 6.2 Join Date: Feb 2019
update on the difference in those two black ports?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
Thread Tools | |
