TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 12-17-2023, 02:26 PM   #1
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Front forward lower control arm bushings leaking fluid(?)
As the title says. Pulled the Z out of the garage for a therapy run this morning and damn near had a stroke when I saw a drop of fluid on the floor.Inspection revealed fluid leaking from both forward bushings. WTF! Anyhow, anybody know part numbers for replacements or aftermarket upgrades if OEM not available? I was glad to see it wasn't a cracked block or some other LS7 related failure but I'm still pissed AND disappointed. I purposely drive the car once a week just so s#!t like this doesn't happen. I hit them with the rag wrench and went for a good 6500 rpm "tour". Stil love this machine!
ariZona28 is offline   Reply With Quote
Old 12-17-2023, 03:36 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Try Rock auto they have GM original.
https://www.rockauto.com/en/catalog/...trol+arm,10401
There is no aftermarket that I could ever find the Z arm is gonna be the best you can find due to its bushings.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 12-17-2023, 08:23 PM   #3
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
Could it be lubricate just leaking out due to temperature? Is there any signs of bushing degradation?
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 12-18-2023, 04:01 AM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
I'm hoping that's all it is. After looking at the Rockauto selection suggested by oldblue I see they're "pre-lubricated". I was wondering if anyone else's Z has this going on. Maybe no big deal. Both bushings still look like new. Less than 7K miles.
Old 12-18-2023, 05:14 AM   #5
cdb95z28
cdb95z28's Avatar
The arm/bushing is the same as at least the ZL1 and SS 1LE arm except the Z arm has the white bushing inserts. So if you cannot find a GM Z/28 arm with the insert, buy the ZL1/1LE arm and swap out your insert into the new arms.
Those inserts are gold. Never toss them in the garbage, they have value.
Old 12-18-2023, 07:33 AM   #6
Roamer63
Roamer63's Avatar
Drives: 2014 camaro 2ss/rs
Mine did the same thing. Decided it was just lube melting in the heat of the summer. It quit after a few days and seems fine now.
Roamer63 is offline   Reply With Quote
Old 12-18-2023, 07:57 AM   #7
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
I would say that is it, I got a whole cabinet full off grease cartridge's and it looks like an oil field in there. Temps and shelf life is when the oil separates.
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
