Old 01-03-2020, 04:57 PM   #1
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Mid spoiler blade/ trunk edge issue
Hi everyone, happy new year and happy holidays. So I just noticed on my car that there is a huge chunk of paint missing/ ripped off. I didn’t take a pic earlier, I’ll do so tomorrow morning, but I posted up a photo for reference. Does anyone have any issue in that area?
I guess I had it all along, even in this photo you can see paint missing on the trunk at the edge of the middle spoiler.
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 01-03-2020, 06:58 PM   #2
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
Mine had that also. The dealer repaired it. The had to remove the trunk and the spoilerto repaint it.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 01-03-2020, 06:59 PM   #3
KPzypher
Drives: 2020 Camaro 2SS 1LE M6
Looks like I'm not missing any paint (summit white), but I have a huge gap on either end. I believe I read somewhere that the end pieces are dealer installed, and if that's true my dealer dealer did a sh***y job. I'm gonna have to redo them at some point.
KPzypher is offline   Reply With Quote
Old 01-03-2020, 08:37 PM   #4
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
That's a separate issue, but GM really should change the process to have the end pieces installed at the plant for more consistent fitment / gaps. There have been several posts on misaligned end pieces.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 01-06-2020, 02:46 AM   #5
beedo
Drives: 18 2SS 1LE NFG
Mine has the missing paint issues as well, I bought touch up paint and clear so it doesn't corrode
beedo is offline   Reply With Quote
Old 01-06-2020, 09:04 AM   #6
madscotsman
Drives: 2018 SS 1LE
^THIS, plus the dealerships put adhesion promoter all over the fender tops, potentially ruining the paint when they mount the winglets. Mine (Red) looked faded and stained under the winglets when I first removed them, until I waxed it with a scratch remover and it sat out in the summer sun a couple days . Not sure if that's how they are directed to do the install from Chevy, but it is definitely not the correct use of adhesion promoter. The 3M adhesion promoter is NOT supposed to be applied to painted surfaces and is only needed to get the double sided tape to adhere to plastic/fiberglass. 3M tape will adhere to the painted surface of a car without issue if the surface is cleaned with alcohol first. Most failures of the tape are when it separates form plastic surfaces or when the painted surface is not cleaned of any wax's or other residue.
madscotsman is offline   Reply With Quote
Old 01-06-2020, 09:52 AM   #7
importunerdj
Drives: Turboed
Well that stinks, I have an appt for tomorrow to have it looked at.
I’m pretty sure my issue is what’s described with the last poster, it looks like the 3m has not adhered to the painted surface and is deteriorating.
importunerdj is offline   Reply With Quote
Old 01-06-2020, 01:27 PM   #8
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I haven't noticed this yet but I need to check now.
Jaxcam02 is offline   Reply With Quote
Old 01-07-2020, 05:30 AM   #9
madscotsman
Drives: 2018 SS 1LE
Looks more like the adhesion promoter ate the paint when they incorrectly applied it to the painted trunk instead of the spoiler side of the 3M adhesive. Mine has a similar area along the front edge of the spoiler on the passenger side. I had a similar conversation (#5 below) with 3M a few years back when I removed some window louvers from a mustang I had.
https://www.bimmerfest.com/forums/ar.../t-788799.html
Old 01-08-2020, 08:30 AM   #10
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
I'm assuming GM leaves them off to prevent and damage/potential theft during shipping. I wish dealers would take better care when installing them.
Mine were so bad they didnt even line up with the spoiler. They were to far out and canted back.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 01-09-2020, 01:57 AM   #11
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
Thank you for this! I mentioned this to the service advisor that this is probably the issue. They couldn't do anything at the time of the appt just assess the damage which is understandable can't imagine them sending it out right now, they said GM wanted pictures and will be in contact with me.
I also showed the advisor my the ends of my spoiler don't exactly sit flush especially the driver side has a much bigger gap compared to the passenger. Hopefully they replace that as well but that seems to be a easier fix if not.
Old 01-09-2020, 03:52 PM   #12
CrazyCatGuy
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE
Thanks for pointing this out. I just noticed my passenger side has a couple noticeable flakes near the trunk lid spoiler. Time to hit up Dr. Colorchip!
CrazyCatGuy is offline   Reply With Quote
