05-22-2018, 10:52 PM | #1 |
Drives: Red Camaro Join Date: Dec 2017
Traction control help
So I recently bought some new tires and recently installed these new tires. I have same size in the rear 275/35/20 and I have 255/35/20 in the front but when I drive my traction control keeps flashing on me. Why is that???
Sent from my iPhone using Tapatalk |
05-23-2018, 07:53 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Flashing TC light means the TC system is active because the car detected some kind of wheel slip and is limiting engine torque.
2017 SS 1LE.
05-23-2018, 08:14 AM | #3 |
I used to be Dragoneye...
Is it flashing at you just rolling down the road? Or when you're driving "spiritedly"?
05-23-2018, 08:55 AM | #4 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
More specific information as to the failure mode is important.
05-23-2018, 12:22 PM | #5 |
05-23-2018, 12:23 PM | #6 | |
There the nitto nt05 and I have a aspect ratio of 35 all around Sent from my iPhone using Tapatalk |
05-23-2018, 12:39 PM | #7 |
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
Did the ABS/wheel speed sensor/wiring get damaged in any way?
05-23-2018, 12:40 PM | #8 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Maybe a bad sensor or damaged during install.
05-23-2018, 12:58 PM | #9 |
05-23-2018, 01:02 PM | #10 |
NT01 in those sizes shouldn't be anywhere close to slipping nor would they have a large enough difference in rolling radius to cause an issue under normal driving conditions. I'd agree with those above that it's likely an issue with the wheel speed sensor.
2017 SS 1LE.
05-23-2018, 01:04 PM | #11 | |
Okay. I’ll take another look and give a update. Sent from my iPhone using Tapatalk |
05-23-2018, 02:04 PM | #12 |
Okay so the light only came on when I started driving. Then later on it never came on again. But it flashes when I’m coming to a complete stop at points.
05-23-2018, 02:32 PM | #13 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
You shouldn't have a problem by just swapping to those NT05's.
Stock wheels? Maybe a dumb question, but I have to ask: Are you sure it's the traction control light? TPMS? Stop by an O'Rilley Auto and get the car scanned. O'Rilley usually has scanners that will read body and chassis codes. |
05-23-2018, 03:11 PM | #14 |
Drives: SS Join Date: Jan 2017
Sometimes the speed sensor or abs sensor needs to be reset. Unplug the battery for 20min and then reconnect.
