11-24-2022, 06:09 PM | #1 |
Drives: 2023 Camaro 1SS 1LE Join Date: Nov 2022
Need male/female connectors for SS 1LE rear quarter panel speakers
Can't seem to find any info on these types of connectors anywhere on Camaro6 or the internet. Its a 2 wire/2 pin connector if anyone has any idea where I can find these connectors, that would be much appreciated. Trying to make a DIY Line Output Converter harness to avoid splicing/tapping into the speaker wires.
Thanks! |
11-25-2022, 09:33 AM | #2 | |
Electrical Engineer
You can get a GM speaker wire adapter pretty easily if you're just going to disconnect the speakers, but since I don't recommend doing that anyway since the rear signal is garbage and you want to keep the front signal: https://www.crutchfield.com/p_003SH3...s.html?tp=3097 Easiest way to do this is to de-pin and re-pin the factory harness at either the factory amp or where it splits for front dash and front door. This way you can add a second wire pair (for each side) to an existing harness that you can then route to the LOC. You'll also want the proper crimp tool since the pins use a 2-stage crimp (conductor separate from insulation). Pins have specific dimensions and you'll want to first get a pinning kit (like $10 on Amazon) then you can remove the pins, measure, and order what you need. If I want to build harnesses and plugs, it's a real tedious process since that process isn't well documented. I've done it before but it took hours of research. You may have luck with a few day subscription to ACDelcoTDS in determining what pins are used. I'll be digging into this myself soon enough, but I may wait until spring. I will route the front signal to a DSP then run a front 3-way active. I may remove the windshield to both remove the headliner and have access to the dash corners to mod for the mid/tweet combo.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
11-25-2022, 10:27 AM | #3 | |
https://wildhammermotorsports.com/19...rness-gen5diy/ might go this route if my assumptions of this product are correct. I will be contacting GEN5DIY to get more info. |
11-25-2022, 04:00 PM | #4 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
11-25-2022, 09:15 PM | #5 | |
11-27-2022, 07:21 PM | #6 |
So while we’re on the subject…and as I’ve mentioned in a couple of previous posts, I deleted the rear panel speakers and added some decent rear deck speakers and an amp. While the overall system sound quality is much better, we’re all on the same page as far as to the rear signal being garbage (lessen learned by me).
I recently purchased an inexpensive, but better component set than (hopefully) the OEM fronts. At this time, I don’t plan on installing an amp for those. However, I’m considering buying the Gen 5 harness and paralleling the front signals for the rears. The problem with this is volume control for the rears. Can I use a simple / rheostat knob with RCA’s snipped off /wire through to the inputs of the rear amp for the rear speakers? I know this NOT the best solution. I’ve already spent a couple bucks and effort on the rears, so it would be nice to liven them up a bit… if reasonable / possible. Any help would be appreciated. |
11-27-2022, 08:40 PM | #7 | |
Matt Miller
2020 SS 1LE |
11-27-2022, 09:10 PM | #8 | |
The other question I forgot to ask…is if I’d need to be concerned with tapping the fronts signal and leaving the rear signal “dead ended”. Should a 4 ohm resister be installed on the rears signals (just to protect circuitry). |
11-28-2022, 08:39 AM | #9 | |
Matt Miller
2020 SS 1LE |
11-28-2022, 02:59 PM | #10 | |
Electrical Engineer
Totally fine to leave the rears open. An open circuit is just no connection, the amp won't care and won't generate heat because of it. You can increase gain to compensate for the rear signal weakness but then you get a lot of noise. Just avoid the rear signals in most circumstances. In some systems, in the past, I would use rear for the sub and front for the speakers so the user could let the fader act like a sub level control. But with amps having their own knobs these days, it's no longer a useful trick.
11-28-2022, 04:39 PM | #11 |
Thanks Matt, I actually did a bit of research last night and you’re right. I can safely leave the rears open. I’ll try adjusting the gain before adding potentially unneeded equipment.
11-28-2022, 04:42 PM | #12 | |
Tags |
connectors, speaker, wire harness |
