Old 05-20-2018, 07:47 AM   #1
Number 3
Hail to the King baby!
Number 3's Avatar
All New 2.7L Turbo
A lot of people have stated they would take the 5.3 liter V8 from the trucks in order to get a "low cost" V8.
How many would take the All New truck based 2.7L 4 cylinder turbo? At 310 horsepower and 348 pound-feet of torque it's a big improvement over the 275/295 currently in the Camaro 2.0T L4.
Much more torque than the V6 also (284) but still down a bit on HP.
Interesting. This was under discussion when I was there as a FE alternative in the FST. Looking forward to seeing those numbers.
https://www.autoblog.com/2018/05/18/...-pickup-96858/
Old 05-20-2018, 08:03 AM   #2
yankee
yankee's Avatar
Drives: 2018 Camaro LT RS, 2015 Mazda 3
If they would add this engine in 2020 version and bring back the sexy 6th gen look....
But a man can only dream
yankee is offline   Reply With Quote
Old 05-20-2018, 08:15 AM   #3
Gen6_1Le
Gen6_1Le's Avatar
Drives: 2018 Camaro 1Le
Would make a perfect base motor for the Camaro CUV .
Gen6_1Le is offline   Reply With Quote
Old 05-20-2018, 09:03 AM   #4
fastball
Drives: 2017 Camaro 2SS 6MT
That's an interesting displacement for a 4 cylinder. What's the bore x stroke on that puppy? Some pretty good sized pistons or a large crank.
fastball is offline   Reply With Quote
Old 05-20-2018, 09:11 AM   #5
AZCamaroFan
Camaro6 2016-2018
AZCamaroFan's Avatar
Drives: sometimes
sounds alright to me if it's in a good looking Camaro
Old 05-20-2018, 10:11 AM   #6
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Ah but it wouldn't sound alright. Hate the sound of a 4 banger.
craigss50 is offline   Reply With Quote
Old 05-20-2018, 10:12 AM   #7
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Yeah that's an interesting engine reminds me of koenigsiggs value trick plus new turbo and more new tech..the numbers are impressive and definitely would fit the camaro..
Old 05-20-2018, 10:55 AM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
As spec'ed, it's a low to medium rpm truck engine. With torque stated as dropping off from 4000 rpm, I doubt its peak power rpm is much past 5300 (if it's that high).
A sporty car really needs an engine with higher rpm capability (and not be as coarse as a big 4) to match its character.
I'd like to see a 6.2 destroked to 5.6-ish with the 4.8's 3.3" stroke. A little bigger than 5.3L, with higher rpm potential.
Norm
Old 05-20-2018, 11:03 AM   #9
Number 3
Number 3's Avatar
Norm
It's definitely tune for the truck application which would mean focus on torque down lower in the RPM band. After all, it's probably hauling around 4,500 pounds and up compared to the 2.0 in the sub 4,000 pound cars (CT6, CTS, ATS, Camaro).
I don't see them doing a lower displacement LT1 simply because the cost would be identical for less HP. And yes, you probably can rev it a little better with smaller pistons. So the question there is simply "would you pay the same money for less HP?" Unless you have even more in mind....
Old 05-20-2018, 11:04 AM   #10
fastball
Norm
So in other words, a return of the 350
They were getting 325 hp out of the 350 in it's last iteration around 2002 with the ram air package in the old F-bodies so there's no reason to think they can't get 400 hp out of it now with 30+ mpg on the highway.
Old 05-20-2018, 11:18 AM   #11
Norm Peterson
Sort of. Almost like a 400-block/327 crank version of the older SBC.
[/quote]They were getting 325 hp out of the 350 in it's last iteration around 2002 with the ram air package in the old F-bodies so there's no reason to think they can't get 400 hp out of it now with 30+ mpg on the highway.[/QUOTE]
I can see a little over 400 HP with LS7 or better rpm capability being entirely possible.
But it might take having to squeeze more mpgs out of the V8 than can realistically be done with 6.2L, assuming that the oversquare configuration can be made to meet emissions.
Norm
Old 05-20-2018, 11:24 AM   #12
F1FTY
Drives: 2018 ZL1
Love the idea. Would Chevy then copy Mustang and drop the V6 in this scenario?
First, you'd have to see how much the unit cost is vs. the current V6/I4 currently offered.
I would be surprised if it were lower than either engine due to current economy of scale with that I4 and V6 being used across GM platforms globally. We would also need to know the internal sales figures for the current I4/V6 vs. the competition to see if there is a need to improve the cost leader engine too.
In terms of the engine itself, I'd imagine that some cam and timing changes might be able to turn it into a higher revving engine...it doesn't need to be an RPM screamer for the base model cars...the LT1 surely isn't.
edit: Also forgot to mention the impact having this engine alone would have on CAFE, footprint FE targets on the fleet. With the Co2 regulation in limbo, that may need heavy consideration as well for the US, but more so globally for co2.
F1FTY is offline   Reply With Quote
Old 05-20-2018, 11:39 AM   #13
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
They we're getting 350 or more, they just claimed 325 to make the Corvette look better. Hot rod or super Chevy or someone took a WS6 TA and a Vette in 98 and put them on a Dyno back to back. The TA made a couple more hp
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 05-20-2018, 01:15 PM   #14
AZCamaroFan
Camaro6 2016-2018
Drives: sometimes
possible. i don't think i've ever been in a turbo four.
Looks always come first for me though. It has to look good, and in this case look like a Camaro.
