06-25-2020, 12:46 AM | #1 |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
Battery question
Hi guys
As you maybe know, I had some troubles with a toasted battery during the shipping...(from canada). So I changed it : 600€ (nearly 680 dollars). I Wish I didn’t change it every year... Some of you advise me to get a Ctek.... some of you thé optimate (if my memory is good). For thé first one, i saw a lot of bad Notices (toasted after two years, heating probleme...)... nothing for thé second one, I havn’t searched yet My question is simple : Why would it be bad for thé car to unplug the battery and connect it when you want to drive it? I know that it’s needed to configure the glasses.... and somebody told me the camera also... Thanks a lot for your help guys🙂🙂🙂🙂 |
06-25-2020, 06:14 AM | #2 |
Retired from Car mfrs....
I did this for a couple months a year ago, I had a battery disconnect switch on the battery, and would turn the battery off and disconnect every time I got done with the car. It was fine. No problems, the car will ask you to re-index the windows by rolling them up and down once when you reconnect.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
06-25-2020, 11:15 AM | #3 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
^ that's what I don't want to bother with, resetting stuff every time the battery is disconnected
Put an Optimate on it and forget it. Yes CTEK is junk |
06-25-2020, 11:47 AM | #4 |
Drives: 2020 RGM ZL1 Join Date: Jun 2020
Batteries for this car cost 600euro in France?
'20 ZL1 Rally Green Metallic
-work in progress '06 GTO Spice Red (RIP) -Full Pedders, K&N, Ported TB, FAST Manifold, SW Exhaust, Stoptech Brakes, DBA5000XS |
06-25-2020, 11:50 AM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Also, if you're required to get an annual safety inspection that includes a smog check via OBDII, you will fail several readiness codes, requiring you to drive a certain sequence and/or number of miles to get them cleared.
Crap, better throw mine out I've had for the past 12 years.
06-25-2020, 12:30 PM | #6 | |
Drives: 1of 66 Orange Crush 2020 ZL1’s Join Date: Dec 2016
Dreaming of a 2020 A10Crush ZL1 *TPW Sept 30* Built November 14, 2019, shipped Nov 15, 2019. Arrived at the dealer January 29, 2020.
2013 CTSV coupe 6MT SOLD |
06-25-2020, 08:44 PM | #7 |
Joining the choir, mine is the standard 84020223 trickle charger from CTEK, been working fine since I bought it mid-2018.
06-25-2020, 10:16 PM | #8 |
Good luck, mine crapped out in about 2 years and always ran hot.
The Optimate6 is simply better quality and it's not even close, most people don't don't know about them so stick with what they know |
06-26-2020, 01:05 AM | #9 | |
06-26-2020, 01:07 AM | #10 |
06-26-2020, 01:12 AM | #11 | |
I’m afraid of it. In France thé Car technical inspection is hard Mine failed at the french homologation with a p300 code ... because of thé battery..... (I think) Thé codes had to be clear and I’m gonna drive to it to see if it’ sur good... Somebody has a optimate référence that could correspond with the french system... I found for the ctek but not for thé optimate .... |
06-26-2020, 08:30 PM | #12 |
Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
You can buy in your french shop the Varta E39, is the one that I use in my car.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
06-27-2020, 06:33 AM | #13 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
I know you folks across the pond are getting soaked on fuel and oil due to oppressive taxation but how does a $150 (USD) AGM battery end up costing $680?
You would be better served hooking up a battery tender, connect the quick disconnect pig tail to the under hood jump point and ground and stick it out the grill. I have been using Battery Tender brand for decades on my motorcycles and generator with excellent results. My car came with the GM one pictured above but I've never used it so I can't comment. https://www.amazon.com/Battery-Tende...NsaWNrPXRydWU= |
07-01-2020, 12:39 AM | #14 |
