Old 06-24-2020, 12:36 PM   #1
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Starter lags when hot
If this has been covered, sorry, I did a search and nothing came up.
Anyway, over the last couple of days, I have noticed that my ZL1 starts right up when cold. But, after driving for a few hours and the outside temp is over 90 F, the starter seems to lag, almost like the battery is weak. But, a test shows it fine
And, when the engine is cold, the starter sounds fine.
Anyone else notice this?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 06-24-2020, 01:02 PM   #2
VinnAY
Drives: 18 1SS/1LE
Starters at least used to be susceptible to heat especially in hot rod type applications and especially where headers are involved but I'd have to say it's much less common in modern cars and isn't too unusual.
Old 06-24-2020, 01:09 PM   #3
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
This sounds crazy but usually that's a sign of a higher compression motor(Which should not be with a factory motor), but I wonder about your timing which should not be off.
I hope it's a small issue, maybe a weak starter, get it hot and take it to the dealer and let them here it.
Revalot is offline   Reply With Quote
Old 06-24-2020, 01:49 PM   #4
SteveV
SteveV's Avatar
Motor is bone stock
The only things I have added to this car is a dry Green filter in the stock air box and an 8 ball shifter handle.
No headers, still has the full factory exhaust.
Old 06-24-2020, 02:06 PM   #5
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Very common on 2016s from what i know. The starters heat soak, but i thought they added additional heat shielding from 2017 on. Mine almost didn't start at all 2 weeks ago after driving to the gas station directly from a 93 degree track session.
Old 06-24-2020, 05:42 PM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes SteveV my ZL1 is like that too and my 2016 2SS that I had was real bad about doing it too. Actually the SS was worse than the ZL1 especially when it was real hot outside.
Old 06-25-2020, 01:13 AM   #7
AZ_1LE
Drives: 2019 ZL1 1LE
No issues with my 2017 here in Phoenix. It was 110 today.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 06-25-2020, 07:18 AM   #8
LT4Greg
LT4Greg's Avatar
My ZL1 doesn’t do it all the time just intermittently.
Old 06-25-2020, 09:16 AM   #9
LJS-ZLE
LJS-ZLE's Avatar
Drives: 2019 Camaro ZL1 1LE
My 2019 ZLE has weak starts following a track session and I just attribute it to heat soak. I had a 2017 Cadillac CTS-V and that car sometimes would not start after a 25 minute track session and would need to sit for a little while before it would start up again. So at least the ZLE is an improvement.
LJS-ZLE is offline   Reply With Quote
Old 06-25-2020, 09:31 AM   #10
Snowwolfe
Drives: CTV5 V Blackwing on order
My C6 was prone to heat soak on really hot days after the A&A SC was installed on it. I got into the habit of popping open the hood when ever I parked the car. That little opening was enough to get rid of the heat soak.
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 06-25-2020, 02:28 PM   #11
Hell Raiser
To fast is not enough
Hell Raiser's Avatar
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo
I would say a bad starter or negative battery cable is not grounded good, The hotter the starter the more resistance so a bad ground could cause this. When they did your oil pump they could of not done it right when they connected the cables.
Hell Raiser is offline   Reply With Quote
Old 06-25-2020, 05:49 PM   #12
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
My SS had the slow start issue bad. Replaced battery a year ago, never had the issue since. I firmly believe the fault is in the crappy OEM battery.
soloknight6 is offline   Reply With Quote
Old 06-28-2020, 09:17 AM   #13
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Wifes car developed it I'd ck the cables on the battery they tend to loosen some how. Fixed our problem.. my zl1 did same but I got stability light and car shut off out of the blue. Grab hold of the terminals if you can twist the terminals at all it's to loose.
Old 05-26-2021, 09:30 PM   #14
tmak90
Drives: Camaro ZL1 1LE
I've had this same issue even with cold starts to where it takes 2-3 times for the car to finally turn over when remote starting.
The most common occurrence I've noticed this happening is when I go to pump gas and try to start. It takes 2-3 times of me pushing to start to get it to finally start the engine.
I've taken my car to the dealership they said it was due to a bad battery so then replaced it. Couple of weeks later the same issue popped back up and I'll be taking it back to the dealership again tomorrow..
I've read somewhere on this forum that there was a possible fix by adding a new ground cable that connects from the engine to the frame. Has anyone tried this possible solution?
tmak90 is offline   Reply With Quote
