View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 20 13.79%
2017 53 36.55%
2018 67 46.21%
2019 2 1.38%
2020 2 1.38%
2021 1 0.69%
Voters: 145. You may not vote on this poll
Old 07-01-2020, 10:43 AM   #463
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
They did mine without removing the motor.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-02-2020, 05:09 AM   #464
IneedAZ
IneedAZ's Avatar
How much time do u think it adds to a cam change job doing the pump if still in car?
Old 07-02-2020, 06:22 AM   #465
SteveV
SteveV's Avatar
Since you have to disassemble the front of the engine to do both, one would think it would not add more than 20 or 30min of time.
Old 07-02-2020, 07:34 AM   #466
L78toLT1
L78toLT1's Avatar
If you drop the pan, this^ is correct. Some guys have managed to snake the timing chain off without dropping the pan and removing the pump.
Baby Blue
Old 07-02-2020, 08:30 AM   #467
IneedAZ
IneedAZ's Avatar
thanks for the replies. Reason i asked is the shop that might be doing the cam was telling me its a lot of extra work and in turn a lot more money.
Old 07-02-2020, 09:28 AM   #468
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
It is, because the lifters are on top of the cam, it doesn't just slide out with the oil pump out of the way. The chain is also behind the bump. In addition, you have the fuel pump on top that is riding on the cam.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@DemonWorksPerformance
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 07-02-2020, 09:58 AM   #469
IneedAZ
IneedAZ's Avatar
In my post i am referring to the fact they want to charge me extra to remove the oil pump when they change my cam. I want the oil pump replaced with latest part number while they are in there.
Old 07-03-2020, 12:10 AM   #470
DemonZL1
199
DemonZL1's Avatar
Ah, I see. Yeah I misunderstood.
If they are changing the chain, it’s no additional labor because the pump has to come off. If they are not replacing the chain, then I would be concerned.
Old 07-05-2020, 06:13 PM   #471
GRUF78
GRUF78's Avatar
Drives: 2018 ZL1 1LE
Another failed oil pump
FYI....
Wife's 2018 ZLI 1LE M6, 6300 miles. Impeccably maintained. Oil pressure went to zero after running normal RPM for 10 minutes then to idle. Shut down immediately. Oil level full.
Car build date 10/17. Off to dealer tomorrow PM.
GRUF78 is offline   Reply With Quote
Old 07-06-2020, 02:06 PM   #472
bmlocal175
bmlocal175's Avatar
Drives: 2018 ZL1 Black M6 PDR
With the holiday weekend just got the phone call...Oil pump, no engine damage, waiting on parts.
I know nothing about engines so I'm assuming they can check parts of the engine without it running to verify no damage? I saw the turn engine off notice and literally rolled a few hundred feet into my friends driveway and turned it off. Maybe if the pump exploded and pieces went into the engine it would be a different story.
bmlocal175 is offline   Reply With Quote
Old 07-06-2020, 02:31 PM   #473
Alponcho
Drives: 2018 Camaro ZL1
Originally Posted by bmlocal175 View Post
...Glad it's over. Been reading about this for months and it finally happened. Worried about driving it to far and being stuck somewhere.
I kind of feel the same way about my 8/17 built ZL1. The rate of failure is higher than it should be, but still pretty low, and it's covered under warranty, so probably not rational to stress about it too much, especially if the car stays local. My concern is on trips when I'm hours away home--waiting for a tow and having to find a rental car can be a real pain! I've thought about purchasing the latest version of the oil pump and changing it myself (or paying someone to do it), but I'm concerned this might give the dealer an excuse to void the engine warranty if something else were to happen or the pump fails again.
Alponcho is offline   Reply With Quote
Old 07-06-2020, 02:43 PM   #474
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
With the holiday weekend just got the phone call...no engine damage.
Of course they're going to say this but I wonder how they really know
ZX-10R is offline   Reply With Quote
Old 07-06-2020, 02:54 PM   #475
JasonSB
Drives: 2018 ZL1
I have set up a time to get the pump replaced by a local shop. I don't want to worry about it any longer and being modded, I'm sure GM will blame it on the mods if it does go and not warranty it.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
JasonSB is offline   Reply With Quote
Old 07-06-2020, 03:08 PM   #476
Alponcho
GM should extend the engine warranty with the repair to give owners peace of mind after a repair like that. I can't recall the exact details, but I believe BMW extended the 4yr/50k mile warranty on my 02 M3 to 6yr/100k miles when they replaced the rod bearings (service campaign) after only driving 2k miles. That made me feel better about the car.
