TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 07-21-2012, 12:45 PM   #15
yessitsfast
yessitsfast's Avatar
Drives: 2010 camaro
Originally Posted by Jorbob View Post
Sorry, I think im confused. I got this service stabilitrak after ARH header install. No codes, just this service stabilitrak. In order to install the ARH headers, you need to disconnect the steering shaft that runs right along the engine bay area to get the headers off and on. So Im think I messed something doing that... Is what you guys are talking about near the engine bay, or is this something under the dash near the steering wheel itself? Or do you literally have to take off the steering wheel to get at it? Once the steering shaft was disconnected, I could freely spin the steering while inside the car from the engine bay, so I could have twisted it a few times trying to get it all back together?
Thats exactly what you did. Try this... turn the wheel gradually right or left until the light cuts on. Then turn the wheel all the way to the left and right to have an idea which way you are off center. Then rotate the sensor or the steering shaft(disconnect at steering knuckle) the opposite direction. Basically your sensor is telling your computer that the wheels are turned at some impossible angle and it doesnt like it. When this happened to me i had to disconnect the steering shaft and turn the wheel back to the right and reconnect because i let it spin about 3 turns during my header install. No problems after that.
Hockey stripe.Painted emblems.Painted factory rims. Selfmade halos. 35% Window tint. C.A.I intake. "ghetto" mbs long tube headers.
yessitsfast is offline   Reply With Quote
Old 07-30-2013, 07:50 AM   #16
DZ28
DZ28's Avatar
Drives: 2023 ZL1 M6 Riverside Blue
Need to bring this back to life. Installed a 1LE suede wheel and have the service stabilitrak issue. I've taken the wheel back off twice and reset the clock spring by winding it 2.7 turns to the right then back to center 2.7 times with the yellow indicator in the window. I simply cannot get the stabilitrak light to reset. Suggestions other than letting a GM dealer monkey with my very cool 1LE steering wheel and NEW clockspring?
** Sadly SOLD ** IBM 2SSRS Camaro M6... 2023 Riverside Blue ZL1 M6, 1 of 75
DZ28 is offline   Reply With Quote
Old 11-25-2014, 10:52 AM   #17
AF1Strider
AF1Strider's Avatar
Drives: 2011 Camaro 1SS/RS
Any one have a solution on this? I took my wheel off yesterday and now I have all the traction lights on and no codes. My clock spring came apart when I pulled the wheel off but I got it all back together and centered it before I put the wheel back on and now I have the problems.
AF1Strider is offline   Reply With Quote
Old 11-25-2014, 12:05 PM   #18
DZ28
DZ28's Avatar
I still have not serviced mine but suspect this procedure will need to be done at the dealer in the spring.
Old 11-25-2014, 12:36 PM   #19
AF1Strider
AF1Strider's Avatar
Does that have to happen when ever you disconnect the angel sensor? Because I definitely did disconnect it to fix my blinker return problem.
Old 11-25-2014, 12:45 PM   #20
DZ28
DZ28's Avatar
Not necessarily; my problem was in the process of taking off the wheel the clockspring was damaged. Replacing it throws off the yaw sensor. 30 minutes of labor at the dealer and problem can be solved but I'm very picky where I take my car and will only have the work done in the service lane. My local GMC/Cadillac dealer will do that for me and will tolerate me canceling appointments as a result of it raining.... which has happened twice! So come spring I will finally get the car in!!
Old 11-25-2014, 12:58 PM   #21
AF1Strider
AF1Strider's Avatar
Well I opened up the clock spring when I pulled the wheel off, nothing was damaged and I rewound the wires inside and installed it with the sensor in the right spot. And then I disconnected everything to see why my clicker wouldn't reset and fixed it and put it all back together and now I have this stupid stability track warmonger and all my traction lights are on. So freaking frustrating....
Old 11-25-2014, 01:04 PM   #22
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
That clock spring has to be in the correct position, ie - so many turns from the end is "center". I broke mine on removal, and it wasn't until I got a new one that I realized where the marks were, etc. Was definitely a pain.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 11-25-2014, 01:53 PM   #23
AF1Strider
AF1Strider's Avatar
Well I have it centered and I can see the yellow mark in the window at the bottom. Doesn't seem to matter where I spin it the lights and service stability track are always on... This computer crap is really frustrating...
Old 11-25-2014, 04:10 PM   #24
AF1Strider
AF1Strider's Avatar
Well I'm taking to the dealer in the morning to mess with the steering sensor hopefully this fixes it or I'll be buying a new clock spring and a new angel sensor.... This crap is ridiculous....
Old 11-26-2014, 10:58 AM   #25
AF1Strider
AF1Strider's Avatar
Okay so just got home from the dealer and they reset the angle sensor and everything is cleared. So if you every disconnect that sensor it needs to be reprogrammed, lesson learned!
Old 02-11-2018, 06:43 PM   #26
Scotty D
Drives: 2014 1le 1SS CRMT
I did a HUD Saturday and thank god for the thread . Because I to messed up my clock spring !!! And set off my stability track . Was driving me crazy until I read this post . Thanks guys ! Saved me a huge headache and $$$
Love this forum !!
Scotty D is offline   Reply With Quote
Old 03-27-2019, 01:04 PM   #27
Andred1971
Drives: 2010 Camaro 2SS
I did my HUD this past weekend too and broke the clock spring removing the wheel. Put in a new one that has a "clamp" holding it in the centre position. But lights are still on. Am I correct that a dealer has to program the new clock spring?
Andred1971 is offline   Reply With Quote
Old 03-27-2019, 02:31 PM   #28
DZ28
DZ28's Avatar
You are correct, dealer, or service tech with a GM Tech 2 tool, is required. I never did have mine done but suspect the gentleman who purchased my car did.... it can be annoying... and I'm still pissed I buggered mine up!
stabilitrak, steering wheel
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Ace Custom Steering - Name Your Wheel! SparksAI Interior Parts & Accessories 30 04-13-2011 03:44 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Customize Your Steering Wheel In Any Leather & Stitching Colors (Pictures) dsvcustoms Interior Parts & Accessories 4 09-06-2010 12:50 AM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 02:13 PM
