04-06-2018, 04:12 PM | #85 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Tx
I will buy this 7440/7443 led and try that Appreciate your cooperation |
04-06-2018, 05:35 PM | #86 | |
Drives: Camaro Coupé 2.0T AT8 (EU version) Join Date: Mar 2016
See you!!, Eos |
04-06-2018, 05:39 PM | #87 | |
See you!!, Eos |
04-16-2018, 08:25 PM | #88 |
Drives: 2017 2SS NGM Join Date: May 2012
05-08-2018, 07:42 PM | #89 |
Drives: 2 x 2016 2SS Camaros & 2015 Camaro Join Date: May 2016
Rear Euro fog reverse lamp
Hi, I have the Euro rear reverse/fog lamp and fitting it to a 2SS. I am after a part number for the wiring harness that plugs into it. Or a European Camaro VIN that has that lamp standard. Any euro guys can help? (# 14 on the drawing below)
05-09-2018, 09:54 AM | #90 |
05-09-2018, 11:44 AM | #91 |
Thanks Eos!
05-22-2018, 10:13 AM | #92 |
Drives: Ford Focus Join Date: May 2016
One Question, is the EU Camaro also "hurt" by the skip-shift feature (CAGS)?
05-22-2018, 12:23 PM | #93 |
Drives: 2018 Camaro 2SS (European Version) Join Date: Mar 2014
05-22-2018, 05:50 PM | #94 |
05-22-2018, 05:58 PM | #95 |
Drives: 2016 Camaro 2SS Join Date: Nov 2016
06-15-2021, 01:28 AM | #96 |
Drives: 2017 2SS Convertible Join Date: Mar 2021
Quick question here. In the EU version is radio using the odd and even frequencies? And if yes is this the same or different module? Asking as I try to understand if there is a way to simply re-program the US version (without using the external modules as it is being suggested). I assume that GM did not create 2 different radio units - just one but with different settings to reduce cost.
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust modification to 4 tips (non-NPP), LED rear fog light (EU requirement), side-markers conversion to LED Mods planned: Morimoto LED lamps set (front) |
06-26-2021, 10:27 AM | #97 | |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
US to EU radio frequencies
https://www.ebay.co.uk/itm/US-FM-Ban....m46890.l49286 https://www.ebay.co.uk/itm/US-FM-Ban....m46890.l49286 Just let the sellers know what kind of car this is intended to go on and that it uses a FAKRA antenna connector. This is the photo of the band expander that I plan to fit on my car's radio control module. It plugs-in between the antenna connection and the radio control module that is located behind the glovebox and needs power. I was told that the display will still show the 'odd' frequencies' but will tune .1 higher. To save you some brain-boiling research time, if you ever decide to go for one of those, it needs to get powered through a Retained Accessory Power (RAP) source, so that it is powered while the radio is on. You can use the purple wire that goes to the lighter under the center console (that's what I will do). It's fairly easy to remove (actually lift) the center console. I will do the installation next week, so I will let you know how it goes. If however you find a way to reprogram the radio to show even frequences (or both odd and even) please let me know.
Mosaic black 2018 Camaro 2SS A8 (sold) |
