09-04-2019, 07:26 PM | #29 |
Drives: '18 1SS 1LE Join Date: Sep 2017
I only see front specs for "after" in Oct. No rear and no "before".
'18 1SS 1LE Black, PDR
09-04-2019, 10:33 PM | #30 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
In any case, it would be vital to check current specs, to see if they walked between May and now. If the same shop then i would reasonably suspect they have again. But no idea when those tires were put on, so... |
09-05-2019, 09:09 AM | #31 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
I will be going back next week to have them check current specs. I'm having the PS4S's mounted next week. Not going to drive the car until then.
I will immediately go to a high performance alignment shop for an OEM alignment, and then check it regularly. Everything is bone stock. Suspension is set for track. There have been no impacts or damage. I can't see it being a rubbing issue because the left side is showing the same thing, but much less. I did not post the rear because I didn't think it was relevant. As far as the inside tread being done, I disagree. It might not show clearly, but I looked carefully and the inside tread is only slightly more worn then the rest. Good lesson. ONLY go to a high performance alignment shop with good references.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
09-05-2019, 11:32 AM | #32 |
Drives: 2018 SS 1LE Join Date: Apr 2016
I had an issue with alignment shop on my daily driver (not my 1LE) I was eating tires. Horrible wear from center to inner treads , it rang true that the technicians were not tightening things up and it was walking. It took me 3 times and a set of front tires worn.
As mentioned a good alignment shop is key and checking the alignment every 6K on the daily. The 1LE has been checked right around few times and it did walk but that was with track use and driving on the twisty. Actually just purchased another set of Goodyear OEMs for $730 from Tire Rack. They posted that they were 2015 production.. but hey that is fine with me. About to start hitting up the tracks again. OP glad to hear your getting that discount from Costco for premature wear. They are pretty good on their tire pricing.. |
09-06-2019, 11:12 AM | #33 | |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
How i understand it for the front suspension, the only loosening and tightening up to adjust toe would be the jam nut on the outer tie rod to allow it's movement. Are technicians simply not tightening the jam nut? Or it is more complicated than that? |
09-06-2019, 11:48 AM | #34 | |
My 2 cents... advice |
09-13-2019, 01:31 PM | #35 |
Had the new PS4S's installed this morning. Can anyone recommend an excellent high performance alignment shop in the Ft. Lauderdale area?
Mal
09-13-2019, 01:52 PM | #36 | |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Now if you have a friend at the local shop - perfect. Ft Lauderdale - has got to have some decent high caliber shops...
