Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 07-13-2018, 10:05 PM   #1
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
ZL1 Rear Diff Fluid - is RP OK?
I am changing my rear differential fluid this weekend 2013 ZL1. I have really piled up the miles lately and I am now nearing 1800 miles..
I know the manual calls for AC Delco 10-4034, GM#88862624, but nobody stocks this fluid near me.
I am curious if anyone knows if I can use Royal Purple Max Gear 75w-90 Synthetic High Performance Gear Oil w/Friction Modifier Additive? This is stocked at Napa and O'Reilly's.
StreetRage320 is offline   Reply With Quote
Old 07-13-2018, 10:41 PM   #2
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
I would use the GM fluid. I've done my twice (30K miles now) both with the GM fluid. Order it from Amazon or ebay so you can get it in a couple of days.
DrkPhx is offline   Reply With Quote
Old 07-13-2018, 10:47 PM   #3
Mrgwrnch
Pay attention to details
Mrgwrnch's Avatar
Drives: 2012 ZL1
I used the same GM fluid from Amazon, It takes 2.1 quarts.
Mrgwrnch is offline   Reply With Quote
Old 07-13-2018, 11:06 PM   #4
StreetRage320
Thanks, I just placed my order with Amazon for the OEM fluid.
Old 07-14-2018, 08:23 AM   #5
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
I used GM fluid too, it was very easy. Was Pleasantly surprised that both the fill & drain plugs are magnetic.
Read too much of potential groan with name brand fluids,
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 07-14-2018, 03:17 PM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I concur. I put RP in my transmission, but stuck with GM fluid for the diff.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
Old 07-15-2018, 10:44 PM   #7
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Redline is what I use
Crash76 is offline   Reply With Quote
Old 07-16-2018, 10:20 PM   #8
StreetRage320
My AC Delco Diff fluid arrived today and I did my fluid change. Was quite easy. I did drive the car for about 10 minutes to heat up the fluid a bit, only to burn my forearm several times on the exhaust, lol..
I placed my wood ramps on a slight decline in my driveway and back the car up the ramps until level. It gave me enough room to operate under the car safely.
I had seen many reports of low fluid from the factory and heavy metal on the magnets. I am pleased to report GM had my fluid at the exact level and I had very little metal for the break in (IMO). It was more of just a very fine metal/sludge on the magnets.
I attached some pictures that may help someone else who decides it's Diff Fluid DIY time for the Z..
Old 07-17-2018, 02:09 PM   #9
Zillion
Zillion's Avatar
Drives: 2015 Summit White ZL1
Thanks OP!! Seeing how easy this is I'm going to give it a go and replace mine as well.
Zillion is offline   Reply With Quote
Old 07-17-2018, 07:38 PM   #10
7_ws6ta_9
Drives: 2013 ZL1
How much did you put in there? 2.1 or till it spilled out?
7_ws6ta_9 is offline   Reply With Quote
Old 07-17-2018, 08:49 PM   #11
StreetRage320
I put two full quarts in and it did not spill out yet..I then opened the third quart and I made 2 or 3 pumps and it started spilling out. I am not sure how critical those 2 or 3 squirts of fluid are? But our differentials get a workout so I wanted to give it every last drop I could.
Old 07-17-2018, 08:53 PM   #12
StreetRage320
No problem. I am glad it was helpful. If you have an assortment of 3/8 drive ratchet extensions that helps with the top fill port. The exhaust is sort of in the way. But with an extension it is no problem. Very simple procedure and since there is metal and no filter (just magnets), probably a good idea to keep up on the diff changes. That little hand pump I have came in very handy.
Old 07-18-2018, 07:16 AM   #13
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Great writeup on how easy it is. I use Royal Purple LS and have no issues.
Happy_Dan is offline   Reply With Quote
