12-13-2019, 03:12 PM | #1 |
Drives: 17 SS a8 Join Date: Feb 2010
Anyone try the cid heads?
I dropped a valve awhile back and am just now starting to think about working on it. If I am reading this right you can get a set of cid heads from lme for under $4k with titanium intake valve, inconel exhaust valves, valve springs and cnc ported.
Curious if anyone is running them.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
12-13-2019, 06:53 PM | #2 |
Brandon Hill runs them on his NA setup. Car runs low 9's on motor SBE. So yes they bad arse
2016 NFG 1SS A8
12-13-2019, 07:41 PM | #3 |
Brandon car is def bad ass.
12-14-2019, 08:25 PM | #4 | |
12-14-2019, 09:26 PM | #5 | |
I do question that. Seems like a pretty fair price
12-15-2019, 08:47 AM | #6 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Are you planning to modify your headers, you obviously have the skills, or take the easy way out with the Kooks cid specials?
Baby Blue
12-15-2019, 09:56 AM | #7 |
I didn’t know they were any different. I better go do some more reading. I thought it was just the higher end eldebrock heads that moved the ports.
12-15-2019, 04:56 PM | #8 |
Oh, you may be right. I'm probably thinking about the edelbrocks.
Baby Blue
12-15-2019, 08:41 PM | #9 | |
12-16-2019, 11:28 AM | #10 |
I called lme. The price is with their port job but no valves or springs. The price did seem too good. Something like 4700 for the stainless hollow stem intake, inconel exhaust, springs. Something like $5300 with the titanium intake valves. Ports are in the stock locations.
Cid also sells them directly with their own cnc port job.
