11-08-2019, 09:06 AM | #15 | |
Drives: 2019 Camaro ZL1 Join Date: May 2019
2019 Riverside Blue ZL1 M6, PDR
11-08-2019, 09:39 AM | #16 |
You're welcome brother. Hope this swap works out fine, and we're around to help if you happen to hit anything unexpected.
11-08-2019, 04:59 PM | #17 |
Drives: all sold, getting another soon.. Join Date: May 2019
***** EDIT ****
FAIL: I’m sending these back. They worked great with hazards, and the first 4 blinks of a turn signal. But after 4 blinks onwards, they flip to double time *************** Just bought these... https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Installs in 5 mins. Just plug in the bulb, and you're done. Perfect blinking rate.
Larry
11-08-2019, 10:25 PM | #18 | |
(Not wanting to be that guy, but these aren't advertised to have a built-in resistor or CAN bus adapter, or even free of "hyperflash", in fact the description explicitly says you need resistors when used as turn signal bulbs).
11-08-2019, 11:08 PM | #19 | |
Larry
11-11-2019, 08:04 AM | #20 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
Just pulled the trigger on these:
https://www.amazon.com/LivTee-WY21W-.../dp/B07MC47NST No reviews, but they seem to check all of the boxes and whoever is manufacturing these in China is getting the hint now at $30+/pr.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
11-13-2019, 08:53 PM | #21 | |
11-15-2019, 08:10 AM | #22 |
I hack cars.
Drives: Lots ;) Join Date: May 2009
FYI we can program hyperflash out of the BCM; along with some other really cool stuff.
Chris White
Some uhhhh cars. |
11-15-2019, 12:42 PM | #23 |
Drives: 2018 SS 1LE Join Date: Sep 2018
11-15-2019, 06:10 PM | #24 | ||
How about enabling the HUD shift lights on the SS that were oh so pleasantly turned off, presumably to set the 1LE and the ZL1 apart? Is this possible? And video file playback in 720p? Also, can we supercharged SS owners have the boost gauge in the cluster, instead of the battery voltage display?
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 11-15-2019 at 06:34 PM. |
11-16-2019, 12:07 AM | #25 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
load resistors right up installed attached to the led's is a great way to have a short lived bulb.
Just get some load resistors, grab some heatsink epoxy (both things are super cheap) then use any normal led bulb you want (not the stupid can-bus bulbs). Attach your load resistors to the cross members behind each headlight so the heat can go directly into the frame. The whole thing will last forever, cost a couple dozen bucks. |
11-16-2019, 09:39 AM | #26 | ||
I hack cars.
Remote Start Enabled (Customer will still need a remote start key fob to utilize it) Remote Start Cycle time extended to 20 minutes per cycle Factory Alarm/Theft Deterrent Added to base model trucks Factory Heated seat support added for trucks that don’t have it (wiring required obviously) Turn signal “Hyper Flash” Deleted Turn Signal Bulb Outage Detection Deleted Fog lamps remain on with High Beam Fog lamps no longer disable Intellibeam Fog lamps remain on with Intellibeam/Auto High Beam enabled (if equipped) Tap to pass (turn signal activation) bumped up from 3 to 4 flashes Windows down from key fob added (For 2014-2015) Windows down from key fob changed to Driver and Passenger front Windows only Window down from key fob changed to allow “Vent” setting (release key fob to stop window motion prior to complete lowering) Driver (and passenger on utilities) window UP from key fob (hold lock to raise). Express up windows are required to make this work and currently the K2 Pickups only have one on the driver’s side. Trucks with a 98MPH speed limiter the limiter is raised slightly to allow a stock truck (a Denali for example) to run a full quarter mile without hitting the speed limiter before the end of the quarter. Quote:
Chris White
Some uhhhh cars. |
11-16-2019, 03:59 PM | #27 | |
12-04-2019, 02:46 PM | #28 |
Petro-sexual
I can tell you that with a 2020, that nearly no LED bulbs, including Diode Dynamics will work without hyperflashing. I ordered 2-sets from DD and three Amazon sets that stated no hyperflash and it remained. I will admit that DD doesn't state '20s won't hyperflash (and didn't expect they would, but was hoping), so I added their resistors and everything is good. Just FYI - 2020s will MOST LIKELY require resistors for LED signals.
Side note - slightly off-topic: I used the Amazon BU LEDs that have remote resistors and those seem to be okay for now. They were about $35. I know I'll go with GenV' for his harnesses soon, but the Amazon BU LEDs are working fine.
