Old 03-17-2017, 09:20 PM   #29
Originally Posted by travislambert View Post
This 128 GB card is a bit cheaper ($41) and it works fine once formatted to FAT32.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This one has free shipping so ends up a couple dollars cheaper.
https://www.amazon.com/gp/product/B0...A3C2UZZKYRDEBM
Smoking deal either way. I just ran my PDR for a good 45 min with the 64 gig card and barely made a dent in it.
I think I'm good.
Old 03-17-2017, 09:23 PM   #30
JustGeorge
ZL1 CRT 1 of 53
JustGeorge's Avatar
Drives: 2012 & 2017 ZL1's
Originally Posted by Ryephile View Post
See the U with a 3 inside it? That's the symbol for UHS-3. You're more than good, it's overkill.
Thank you all for the information.
Here I thought I got a good deal and you guys beat me.
I guess I'll be keeping it.
JustGeorge is offline   Reply With Quote
Old 04-03-2017, 10:22 AM   #31
67Builder
White knuckled & smiling
67Builder's Avatar
Drives: '17 ZL1 AKA Perfection!
Any issues using the extreme pro version of these cards?
They go up to 512Gb sizes.
https://www.amazon.com/dp/B01J5RH06K..._t2_B0143IISD0
2017 ZL1 A10 CFHood PDR NAV NFG - Order # VCSDRJ
TPW -
3/6/2017 VIN - 1G1FK1R62H0192950
6000 - 04/05/2017 - Delivered!
67Builder is offline   Reply With Quote
Old 04-06-2017, 09:51 AM   #32
ZXCamaro
Drives: Camaro
Do you really need like 10,000 minutes of recording time if that were to work?? I get 1575 minutes of time with a 64gb card. Thats just over 26 hours. That would cover my whole month's of daily driving. Hell a 32gb card is half that and thats still like 12 hours... Save yourself the money. And also dont get the micro SD with the adapter. They are way more expensive. Just get the regular SD card.
ZXCamaro is offline   Reply With Quote
Old 12-03-2017, 09:03 PM   #33
waterman
waterman's Avatar
Drives: Grandad's C2 L89
sub'd for tech reasons.
2018 ZL1 1LE sw/PDR
Old 03-27-2018, 10:11 AM   #34
wlsmoku
Drives: 2018 ZL1 A10
thanks you all for the great info!
wlsmoku is offline   Reply With Quote
Old 03-31-2018, 10:41 PM   #35
dw760
Drives: C3
2018 ZL1 Strike 2
Well first my A 10 had a trans line leak, and now the PDR does not work.
Ive owned a C7 and 17 1LE with PDR. I Kept my scan disc 32GB 10 card that worked perfect I had in the 1LE.
No dice in the ZL1 when I tried it the 1st time today. Gives me the no card or insert card BS. I said what the heck and formatted it quick and long, and it works perfect in my camera's. Still wont work in PDR.
Then tried my micro card with adapter from my Garmin Virb which is the same 32GB 10, it wont work either.
Any other ideas, or is it time for the dealer to try to figure it out.
Thanks Dale
dw760 is offline   Reply With Quote
Old 03-31-2018, 10:57 PM   #36
dw760
Drives: C3
I found this and it makes sense, maybe not even getting a signal from the hub or card insert slot.
https://gm.oemdtc.com/1281/performan...rolet-corvette
Old 07-13-2018, 10:05 PM   #37
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
Thanks Dale
Did you ever get your PDR to work? Did you have to get the dealer involved? I'm in a similar situation. I've tried several SDCards (all 32G properly formatted at FAT32) with zero luck.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 07-24-2018, 04:13 AM   #38
MJP
MJP's Avatar
Drives: 2018 Camaro 1LE Summit White
I picked up five cards at Walmart for cheap.
Under $10.00 each, located in the closeout bin.
This is probably the smart thing to do.
The specs for our PDR SD card are becoming yesterdays outdated specs.
You might as well purchase a bunch today, cheap at closeout, rather than have no option for a card two years down the road.
Purchase several at the highest spec you can find.
Unless,, Is there a way to update our PDR camera to accept the lastest new cards & software etc?
I'm hoping our PDR's aren't just a throwaway item like the 1st Gen factory GPS units were.
MJP is offline   Reply With Quote
