03-31-2023, 09:50 AM | #1 |
Drives: Chevrolet Camaro SS 1Le Join Date: Oct 2020
Battery Voltage drop new battery
I have a 2020 Camaro ss 1le an my battery hand started dropping below 14v down to about 11v I replaced battery issue is still occurring. Car sometimes has no power an stumbles no CEL or codes. Car has full power some days an runs amazing then sometimes it runs like shit I’m lost.
03-31-2023, 10:26 AM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
I am pretty sure the charging system works like you are describing - sometimes it will be at 12 volts, then it will charge up at 14. It doesn't just charge at 14 all the time. It probably shouldn't fall completely out of that gray zone on the gauge that starts at about 10 o'clock on the gauge.
I think you have two issues going on, though, and whatever is causing your other issue is unrelated. Any mods? The stumbling issue is caused a lot by burned wires near the exhaust or loose engine grounds. -Geoff
03-31-2023, 10:54 AM | #3 |
New battery in a 2017 2SS.
My voltage (at least as reported by the dash gauge) fluctuates from 11.5 to about 14.5. No cranking or other electrical issues. This is how it's supposed to work. That grayed out area shows the "normal" range. |
03-31-2023, 11:15 AM | #4 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Did you check the infamous wiring harness under the coolant reservoir to ensure the harness is not in contact with headers? (possible burnt wires)
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-31-2023, 11:55 AM | #5 |
03-31-2023, 11:56 AM | #6 | |
03-31-2023, 12:27 PM | #7 | |
-Geoff
03-31-2023, 12:28 PM | #8 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Voltage on dash is voltage of charging system, not the battery, it fluctuates by design, increasing and decreasing output as needed, and not related to your other issue.
03-31-2023, 05:08 PM | #9 |
03-31-2023, 09:49 PM | #10 | |
The gauge in this photo indicates 12.75 V, which is perfect. This is a dual function gauge, its display switches automatically between the actual battery voltage (like in your picture) when the alternator is not charging, and the charging voltage of 13.5 to 14.5 V when it is. If the actual voltage ever indeed dropped to 11 V, that'd be a problem, but then you wouldn't even be able to start the car.
04-07-2023, 01:39 PM | #11 | |
04-07-2023, 02:25 PM | #12 |
2018 SS A8 11.85@117.06
Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
what he said
DARK KNIGHT
2018 SS A8 11.85 @ 117.07 GPI Tuned E85 stock tires Roto Fab CAI LT 2 intake |
04-07-2023, 03:25 PM | #13 |
04-07-2023, 07:11 PM | #14 |
ctrlz beat me to it, that's a likely culprit based on the codes you posted.
