Old 09-01-2020, 01:36 PM   #1
Vegas Bound
Drives: 2013 Sparkly Red One
GM DEF 24%
I have a 2016 2500HD. The DEF monitor is stuck at 24%. Dealership says it is a software reset and not covered by warranty.
Anybody else have this issue?
Something has to be causing it to happen. There are tons of related articles on the web going back several years and GM will not recognize it as a warranty, recall or TSB.
Dealerships charge $150 to diagnose, say there is no part failure and reset the percent monitor.
Vegas Bound is offline   Reply With Quote
Old 09-01-2020, 02:46 PM   #2
Speeddmn
Drives: Chevy Silverado
Disco the batteries for 15-20 mins, fill the tank. If it still reads 24% then there is an issue in the tank. There are policies for certain vehicles to be covered on the def heater for 120k miles.
Speeddmn is offline   Reply With Quote
Old 09-01-2020, 06:27 PM   #3
Vegas Bound
Thanks, I was planning on disconnecting the batteries tomorrow morning.
Old 09-01-2020, 07:37 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I picked up BiScan. It's an addon for Torque. Works beautifully to force a regen or reset silly little parameters like this.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 09-01-2020, 10:08 PM   #5
Vegas Bound
Thanks, I'll check it out.
Old 09-03-2020, 10:33 AM   #6
Vegas Bound
Well, disconnected both batteries for over 30 minutes. Still stuck at 24%.
Old 09-03-2020, 07:20 PM   #7
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
I know this doesn't address your problem, but on my Colorado I got tired of DEF issues so I tuned it out.
Iron Lung Jimmy is offline   Reply With Quote
Old 09-03-2020, 09:10 PM   #8
Vegas Bound
I plan on doing DEF and EGR delete soon.
Old 09-03-2020, 09:11 PM   #9
Vegas Bound
Side effect of disconnecting the batteries, now I have to take the truck in to a shop to relearn the TPMS system.
Old 09-03-2020, 09:53 PM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
There’s no relearn procedure like on the 5th gen?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-04-2020, 12:12 AM   #11
Vegas Bound
No, it requires the relearn tool like a J-46079.
Old 09-04-2020, 08:04 AM   #12
Speeddmn
While there, ask the service advisor for a VIS. Should have a special policy for the def heater/reduct. We replace these all the time on 12-17 duramaxs.
Old 09-04-2020, 09:23 AM   #13
Vegas Bound
Every dealership within 100 miles has told me if I take it in to them, they diagnose the issue, find no parts are at fault, I have to pay $150 for the diagnosis and to reset the software. They said software is maintenance and not covered under any warrentee.
What is VIS?
Old 09-04-2020, 09:52 AM   #14
Speeddmn
A vis is from gm global that has a list of all open and closed recalls, along with all applicable special policies, pm me your vin and email and i can send you one.
