Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
View Poll Results: Horse Power at Crank
800 - 825 Horse Power 0 0%
826 - 850 Horse Power 1 16.67%
851 - 875 Horse Power 0 0%
876 - 900 Horse Power 0 0%
901 - 925 Horse Power 1 16.67%
926 - 950 Horse Power 1 16.67%
951 - 975 Horse Power 0 0%
976 - 1000 Horse Power 1 16.67%
1000+ Horse Power 1 16.67%
Good forbid - Engine Failure... 1 16.67%
Voters: 6. You may not vote on this poll
Old 08-02-2020, 04:44 PM   #71
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Car is back together
Got the rollbar finished and installed the interior, just a few more things to black out.
Vicster is offline   Reply With Quote
Old 08-02-2020, 04:53 PM   #72
Vicster
Vicster's Avatar
Drives: 13' ZL1
Wink Black out
Blacked out the tail light bezels and got rid of the plastic push pins. I coated the rear wheels with plasti-dip.
Old 08-02-2020, 04:56 PM   #73
Vicster
Vicster's Avatar
Drives: 13' ZL1
Talking No more Hill Assist YEAH!
Replaced the G-meter with a unit from an automatic Camaro.
Old 08-02-2020, 08:20 PM   #74
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Lookin' good! Diggin the blackout on the whole rear end. Looks mean.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
Old 08-03-2020, 05:13 AM   #75
Vicster
Vicster's Avatar
Drives: 13' ZL1
Thanks
Thank you, Just the front wheels, badging and gills to go. Then It is DYNO time!!!!
Old 08-03-2020, 07:54 AM   #76
dale.c
Drives: 2015 camero
Beautifully done brother, Absolutely beautiful !!
dale.c is offline   Reply With Quote
Old 08-04-2020, 04:04 AM   #77
Vicster
Vicster's Avatar
Drives: 13' ZL1
Thank You!
Thank You, Praise is always welcome!
Thought I would also mention that all the push pins in the front bumper cover have been replaced with screws.
Old 08-04-2020, 08:23 PM   #78
bottletalk
Drives: 15 Camaro 2SS M6
is there a difference between the two?
your build is fantastic, how long has it taken since you rolled the car up your driveway? it looks like you really took your time and enjoyed every minute.
great job! 👍
bottletalk is offline   Reply With Quote
Old 08-05-2020, 12:34 PM   #79
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
I set up a spark misfire in the HP scanner and found that cylinders 3, 4 and 6 are having to many misfires. So have to do some troubleshooting now, awaiting new plugs and coil tester from amazon. Then back to tuning.
I'm curious. what was causing the misfires?
FasNuf is offline   Reply With Quote
Old 08-06-2020, 05:44 AM   #80
Carl Mckee
Drives: Subaru 2017
"is there a difference between the two?"
Yeah, I'm curious about that as well. Any change in features?
Carl Mckee is offline   Reply With Quote
Old 08-07-2020, 07:56 PM   #81
Vicster
Vicster's Avatar
Drives: 13' ZL1
Wink Thanks for asking
great job! 👍
Thanks for asking, from the research I have done the automatic units do not have the hill brake assist built into them as it is not useful.
Old 08-07-2020, 07:59 PM   #82
Vicster
Vicster's Avatar
Drives: 13' ZL1
Wink Thanks fort asking
Thanks for asking, The only thing that is suppose to change is the hill hold assist. I have the front tires off right now as I am painting them with plasti-dip. Will post if I notice any thing else different.
Old 08-07-2020, 08:05 PM   #83
Vicster
Vicster's Avatar
Drives: 13' ZL1
Thanks for asking, it was mostly the spark plugs, I bought a coil checker and all the coils operated great. I was using Brisk racing plugs. I have seen a new plug go bad in an hour, but never 4 at once. This is what they look like, they were gapped for turbo and blower apps. Suppose to have a great spark...
I went back to the NGK's one step colder and gapped them to 0.030".
I also upped the coil dwell time by 10% to deal with the wild cam I installed, a little hotter spark cant hurt! The car fires right up and idles at 750 rpm.
Old 08-07-2020, 08:12 PM   #84
FasNuf
FasNuf's Avatar
Thanks for asking, it was mostly the spark plugs, I bought a coil checker and all the coils operated great. I was using Brisk racing plugs. I have seen new plugs go bad in an hour, but never 4 at once. I went back to the NGK's one step colder and gapped them to 0.030". I also upped the coil dwell time by 10% to deal with the wild cam I installed, a little hotter spark cant hurt! The car fires right up and idles at 750 rpm.
Thanks for the reply. I had a similar misfire situation and still do to some extent. I changed my #4 plug and it helped a ton but I think I need to tighten my gap. I'm currently at .039" @ 14.5 psi boost. I bet if I tighten them up like you did, it'll help.
No issues with the 10% coil dwell?
