Old 03-13-2020, 01:49 PM   #15
Eel125
Eel125's Avatar
Drives: 2019 1SS 1LE shadow grey
Originally Posted by Timbo-1LE View Post
https://m.youtube.com/watch?v=cje5Wj7jBUU
174, validated at 172.8
Just won't pull more in 5th against the air...
....was it one run for $2000 or did you get more than 1
Eel125 is offline   Reply With Quote
Old 03-14-2020, 05:47 PM   #16
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Thanks.
2004YZFR1 is offline   Reply With Quote
Old 03-22-2020, 01:11 PM   #17
german tarquini
Drives: audi s3 2008 bmw 135 2010
Hello, I'm from Argentina, sorry for the English language
camaro ss lt1 v8 auto8 2017 track mode .. sixth gear
My stock car registers 305 km / h at 6400 dash rpm (gps 294.44 km / h) with a slight tailwind and it is surely limited, since then I took a descent and kept the same speed ..
german tarquini is offline   Reply With Quote
Old 03-22-2020, 01:21 PM   #18
You must be running non-stock wheels/tires to have a ~3.6% difference between speedo and actual GPS speed. The latter corresponds to ~182 mph, which is a bit higher than what the limiter allows, did you see it for a few moments (with the tailwind) or for a longer time? Is the car tuned perhaps?
Old 03-22-2020, 02:44 PM   #19
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Originally Posted by csolas View Post
it rode very good smooth like glass
Awww, the beauty of MRC.
That is one thing that still impresses me about this car, even after 1.5 years of ownership. It feels just as good at 100+ as it does at 60MPH. So stable, so predicable. With most cars things get more intense as the speed increases, in the 1LE they stay constant no matter the speed increase.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 03-22-2020, 05:09 PM   #20
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
It was about five runs if I remember, between one and 2.7 mile distance. It did 155 in one mile...
Timbo-1LE is offline   Reply With Quote
Old 03-22-2020, 06:30 PM   #21
german tarquini
Hi
stock tires 275/35/20 good year eagle
all stock..I saw it for 3km and for 2km of slight descent ...
Old 03-22-2020, 08:08 PM   #22
Neil350
Drives: Nike Air Max
The limitation will be set at the OEM tire speed rating. So the 180 MPH posted earlier makes sense, since a Y rating of the OEM Good Year Super Car 3 is at 186 MPH. The manufacturer, GM, isn't going to allow the vehicle to exceed the maximum safety ratings of the equipment, this case the speed rating of a tire.
'18 Camaro SS 1LE
'93 T/A l 398" Gen 2 LT1 l 24X l M6 l 12 Bolt 3.90 l Full suspension l Fikses
'89 T/A GTA 48K mile hard top L98 car
12 F150 5.0 Lariat Super Crew - Stock daily
Neil350 is offline   Reply With Quote
Old 03-22-2020, 09:16 PM   #23
german tarquini
gps photoName:  IMG_0524.PNG
Old 03-28-2020, 02:10 PM   #24
Tango1LE
Tango1LE's Avatar
Drives: 2018 1SS 1LE
Originally Posted by Tim M View Post
Chevy rates the car at 175...seems about right. It is a non-event at that speed.
Tim,
I still love watching your Nurburgring Run in your sig block... I've got to get over there someday!
TC
Tango Charlie
'18 1SS 1LE
'68 SS LS2
'89 RS 'vert
Tango1LE is offline   Reply With Quote
Old 03-28-2020, 04:33 PM   #25
Tim M
Drives: 2018 Camaro SS 1LE
TC: You and me both! I have the same lap with notes reference my lack of skill that is even more entertaining...also posted on Youtube. These Camaros are such good performers...
Tim M is offline   Reply With Quote
Old 04-21-2022, 12:06 PM   #26
ls1smokedu
Drives: 2020 Camaro 2SS
I got to 155 on a closed road in my 20 ss vert and the speed limiter kicked in. If I add a roll cage, etc I will have to look into a tuner but the advisor at my dealership says it will void the warranty. I guess I could return it to stock tune to bring in for warranty service.
ls1smokedu is offline   Reply With Quote
Old 04-21-2022, 12:59 PM   #27
cdrptrks
cdrptrks's Avatar
The exact same tires (including sizes) are used on the Camaro ZL1 which can reach 198mph with stock alignment or a little faster with 0 camber: https://www.automoblog.net/2017-chev...ing-top-speed/.
The dealership can detect if you had a tune previously and removed it...not recommended if you want to keep your warranty.
https://www.caranddriver.com/news/a1...o-ss-grenaded/
'According to Oppenheiser, “If you’re not modifying your car and you take your production car to a track day and you have an issue with one of your parts, it’s covered under warranty. We know when somebody changes their ECM calibration, and we know if they changed to a cold-air intake, we can tell all that. But driving it as you break it in from the dealership, if you have a half-shaft or whatever, it’s covered.”'
Old 04-21-2022, 01:06 PM   #28
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Aero and gearing limited. 180 limit is probably in the computer for ZL1/ZLE?
Here is my fastest...windows down (required).
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
