Old 07-16-2019, 08:22 PM   #113
TrackClub
TrackClub's Avatar
Originally Posted by GunMetalGrey View Post
I had over 50% left on both front and rear prior to the event... Not sure if our brakes would act differently of not since we have different models of car?
They were hot enough to be smoking by the end of the last session...
We have the same Bremboni brakes albeit your discs are slightly bigger and so are the pads. You also have vented pistons (better). There should be zero difference.
Make sure to do a cool down lap before heading to the paddock at the end of each session, ideally with speeds that require no use of brakes at all for a lap (or as close to it as possible). That will prevent majority of a heat soak not only to the brakes, but also wheels, hubs, tires and motor.
If they still smoke from heat, go for a short drive on an access road trying to use brakes as little as possible and pop the hood open from inside the cabin. This will intro more air flow to the whole area.
Upon parking, open the hood fully, to cool them down faster (and help cool down the motor as well).
Old 07-16-2019, 08:29 PM   #114
TrackClub
TrackClub's Avatar
Agreed, started doing that last night and started noticing things I had not noticed before that's for sure.
Excellent!!!
Also note his steering: many of the corners flow real well in *combination* and can be taken with the same steering lock.
This makes for fewer weight transitions - as less steering (which transfers weight) makes for better balance.
The better the balance, the more grip you have
Old 07-17-2019, 09:29 AM   #115
NickyRacerBoy
Drives: 1LE
Yeah I compare/overlay my AIM data to FAST SCCA T1 buddy.
Our MPH and G's are close but I brake many many feet earlier!
His car with him in it is ~3200 while I am @ ~3780!
NickyRacerBoy is offline   Reply With Quote
Old 07-17-2019, 09:42 AM   #116
TrackClub
TrackClub's Avatar
Ya that's what works best imo and that's what pro teams do between team members. Otherwise it can just become a bit of mental masturbation
Pats to Fozzie pls Nicky Bobby and thank you!
PS hope you'll manage to fix that half shaft quickly. Not sure but ZL1 might work as those cars have ediff too and likely more beefy units given power levels. But i know zero about fit etc...
Old 07-18-2019, 05:51 PM   #117
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
Yup always doing cool down laps
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 07-18-2019, 05:52 PM   #118
GunMetalGrey
Excellent!!!
Yes I noticed this with DudeOnTrack in his 911.2 4S as well as some guy in a BMW M2 CS, they both look very smooth in comparison to me.
Old 07-18-2019, 08:05 PM   #119
TrackClub
TrackClub's Avatar
Cool! (Pun fully intended lol!)
Old 07-18-2019, 08:07 PM   #120
TrackClub
TrackClub's Avatar
The key is to link them into a single corner as much as possible to minimize unnecessary weight transfer.
You're on it! Great!
Old 07-19-2019, 03:25 PM   #121
GunMetalGrey
Yeah that's a good way to put it, I think timing, familiarity and anticipation will be playing a key role in this.
Old 07-19-2019, 05:52 PM   #122
TrackClub
TrackClub's Avatar
You are absolutely correct. You nay also find that your car will prefer a slightly different line, etc. So experimentation also pays good dividents once ya get the basics down to a routine. Have fun!
coilover, dssv, track, zle
