04-05-2018, 10:19 PM | #57 |
Drives: 2018 Camaro ZL1 Join Date: Jun 2011
You sure that’s the DEXOS 2 oil? Sent from my iPhone using Tapatalk
04-05-2018, 10:25 PM | #58 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
It says Dexos2 on the bottle.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
04-05-2018, 10:27 PM | #59 |
So where did you get it? Sent from my iPhone using Tapatalk
04-05-2018, 10:35 PM | #60 |
https://www.gmpartsdirect.com/oem-parts/gm-oil-19353135 This should be it.
04-05-2018, 10:44 PM | #61 |
I am curious though if that oil is just this oil that's been out in the UK for a while: https://www.mobil1.co.uk/synthetic-e...esp-0w-40.aspx. Bottle looks the same and the specs are a little bit different compared to the new 0W-40. If I had to guess that may be the European 0W-40 oil and GM is maybe just telling dealers to use it for now until supply for the new 0W-40 is better.
04-08-2018, 11:03 AM | #62 |
Drives: 2017 Hyper Blue SS 1LE Join Date: May 2017
Mine came from a local dealer as GMPD was on backorder. It’s euro spec 0W-40, hence the 1L bottles. It’s what is spec’d by GM so I’m good with it.
It’s ungodly expensive through the dealer, though. |
04-09-2018, 05:15 AM | #63 |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
Hmmm, I'll have to go down to the local Wally-World---thought I saw 0w-40 Dexos down there on their shelf.........5qt containers.........
(can't recall if it was ESP) |
05-05-2018, 05:44 AM | #64 |
Thank you Al Oppenheiser!
Mobil is offering a $17 rebate during May...
https://mobiloil.com/en/promotion/mo...r-oil-may-2018 |
05-15-2018, 10:24 PM | #65 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I am asking as our manuals specifically call for dexos 2 standard in either 0w40 or 5w40 yet this Mobil 1 EST 0w40 is dexos but NOT dexos 2. So it does not match the requirement stated in Camaro's 2018 HP Supplement. |
05-15-2018, 11:13 PM | #66 | |
Looks like it came from Mobil 1.
05-15-2018, 11:59 PM | #67 | |
05-16-2018, 01:33 AM | #68 | |
Drives: Grandad's C2 L89 Join Date: May 2017
Even though they are both LT1/LT4 animals, wet sump/dry sumps are different breeds. It was mentioned in Ask Al, but I haven't seen any movement there. I'm also very interested to see if oil volatility issues from 0W- oils in GDI has been addressed in the ESP formulation.
2018 ZL1 1LE sw/PDR
05-16-2018, 07:49 AM | #69 |
Drives: 16 ngm ss Join Date: Jan 2017
The 1 liter euro spec oil is being used to provide availability to Corvette owners prior to the full release scheduled for 3rd quarter 2018. It is Dexos 2 as clearly indicated on the bottle but not exatly the same, based on the specs, as the new formula which is also Dexos 2. The 0w40 fill caps are being produced in both dry and wet sump versions. So presumably, as indicated in the press release, the new formula is for all LT1 and LT4 engines.
As for why the ZL1 1LE still specifies 15w50 for track use, it will likely see higher temperatures. It can start accelerating earlier and brake later, meanwhile the engine must work harder to overcome the extra aero. |
05-16-2018, 08:28 AM | #70 | |
