Old 12-02-2020, 10:10 PM   #113
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Originally Posted by Tay View Post
I should have stated OEM ZLE sizes. It comes in both a 305/30/19 and a 325/30/19.
Im looking forward to these, but they need to keep the super low price point
JT Camaro is offline   Reply With Quote
Old 03-20-2021, 10:27 AM   #114
cbourbs
cbourbs's Avatar
Drives: 2019 ZL1 1LE
Definitely can't wait to see the results of these tires....Appears you can Pre-order
cbourbs is offline   Reply With Quote
Old 03-23-2021, 08:02 PM   #115
NorthGeorgia
Drives: 2018 ZLE, 2023 C8, IMSA MX-5
Have run 305 AR1s front w/325 G3R rears. Track camber, 6 days of wear so better than 3R, 1,35/36 pace at Road Atlanta, w/ 1,34 capability, 28 cold, 34/35 hot. Maybe not quite as precise as a 3R on corner entry but they definitely work, Good to have options.
Posted my tire telemetry,,, almost same as 3R.
https://www.camaro6.com/forums/showt...=581890&page=2
NorthGeorgia is offline   Reply With Quote
Old 03-30-2021, 10:49 AM   #116
davidwarren
Drives: 2019 SS 1LE
any thought to a stiffer front roll bar to lessen body roll and decrease inside front tire cording?
davidwarren is offline   Reply With Quote
Old 03-30-2021, 11:06 AM   #117
TrackClub
TrackClub's Avatar
Stiffer F sway will reduce grip and load the tires faster, giving suspension less time to settle, which may mean more sliding and more vs less wear (depending on driving style and pace).
I had tried it on my C5Z track car many yrs ago and destroyed outside F in less than a day. Another member here pulverized G3Rs fairly recently with stiffer F sways. Fyi. Cheers!
Old 04-04-2021, 07:35 PM   #118
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
Unless you change the front suspension geometry by reducing the Ackerman angle, you won't stop the increased wear on the inside of the front tires.
"Don't let the sound of your own wheels drive you crazy!"
Tachitup is offline   Reply With Quote
Old 04-05-2021, 10:34 AM   #119
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I'm going to be testing the softer front idea this weekend. I've only seen inner wear on my SS 1LE when I get the G3Rs worn down a lot. Normally outside wear is my issue. It's more common to see inner tire wear on the ZLE due to understeer. Alignment plays a big part.
19" track tires for zl1, goodyear f1 3r, nitto nt-01, toyo r888r
