07-27-2017, 02:45 PM | #1 |
Drives: Black 1SS 1LE Join Date: Jul 2017
1LE brake and differential 1500 mile service
I was just quoted over 350 dollars for the track ready maintenance at a local stealership in LA. Can someone please tell me a more resonable place to have this service?
Oil change to 5w-40 or 0w40 free 170 bucks for brake fluid change over proper boiling point Differential flush No I don't own a personal garage to do this myself. |
07-27-2017, 08:02 PM | #2 |
people to scared to post? is it a reasonable price?
07-27-2017, 09:03 PM | #3 |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
what dealership was this at?
07-27-2017, 11:15 PM | #4 | |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Depending on the engine oil they use that can cost between $60- $120 (10Qts), the diff fluid is $40 (2 Qts), oil Filter $8 and brake fluid ranges between ~$40-$50 (1L) for what the dealer would likely use. Just parts for the fluid changes can be between ~$148- ~$218 One of the performance shops in northern Cal charges $150 for just the Brake fluid change and overall inspection.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
07-28-2017, 12:15 AM | #5 |
the oil change is free
the break fluid service I can see the price considering the machine they described doing it the rear fluid 170ish as well, that one is 40-50 bucks in fluid and 30-40 mins of work, thats whats killing me, if one is free and one is 170 why is the last one 180 as well? |
07-28-2017, 06:48 AM | #6 |
Drives: Sold Join Date: Mar 2017
I bought the fluids myself for 40%-50% their dealer cost. A good bit of your costs are fluids.
If the engine takes 10qts and dealer cost of 1qt is 10.00, then you're at 100.00 just in fluids. The brake service they do takes way more fluid if they're using the machine to do it vs a couple tech and a turkey baster. So you're hit there. I had my diff and engine done yesterday for 83 at the dealer bringing my own fluids and filter. We will do my brakes ourselves because I'm not blowing 5 to 6 pints of Mogul just so the machines reservoir is filled enough. |
07-30-2017, 10:18 AM | #7 | |
07-30-2017, 10:28 AM | #8 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Dealers/most shops work on flag hours so they won't quote 10min for it even though it may only take that long.
07-30-2017, 12:50 PM | #9 |
My fingers are crossed I believe I found a good place for my maintenance. Im going to go with a performance shop in my area.
07-31-2017, 02:32 PM | #10 |
Drives: 2017 Chevrolet Camaro 1SS Join Date: Apr 2017
I just had my diff fluid flushed on Saturday. $258.
